2020+ Explorer front differential fluid guide
Guiziyo
Puerto Rico
2021 Ford Explorer
Thanks for this!
Capacity is 0.6qts. Not sure why the manual specifies to remove the front bottom cover... only removing or pulling back the rectangular cover is needed. The fill bolt is pretty tight loosening for the first time--you may need a breaker bar.
Also: for MY2020-2021, anytime you remove the rectangular bottom cover, look for any signs of front axle disconnect actuator leak (located on driver's side, left of bottom cover) as that will be front differential oil which has a relatively small capacity to begin with.
If you ever replace the halfshaft speed sensor (located on the front differential), you will spill front differential oil and need to top it off.
South Carolina
Is there a drain hole as well? So I can drain the old and add the new fluid?
I used the transfer pump that attaches directly to the quart bottle of oil. It only takes 0.6 qts if I recall.
Oh, and in that link I referred to, you do not have to remove the front undershield--just the rectangular center one.
South Carolina
Ok that works. I have one I bought at autozone. What’s the best way to clean them after I use it? So I don’t cross contaminate.
I try to pump out as much remaining oil as possible and remove the fill straw. Basically just store it to allow any oil to drain out on a paper towel. There is only so clean you can get them. Do the same thing for my larger fluid transfer pump and also for my smaller syringe type transfer pump.
STBlanco
Georgia
What size and type bolt is this? Allen or Torx? Used every size Allen and none of my sockets fit in the bolt, either just to big or just to small and no in between
i used Torx but some are saying it's actually Torx Plus
South Carolina
I used a T50. They say loosen the filler plug first cause it can be tough. Loosened filler plug no problem, a little tough. Drain plug…. Snapped my T50 :ROFLMAO:
Nunya
Interesting that one guide says fill plug 18ft-lbs and the other says 30ft lbs. 24 it is!
I did a stupid thing and filled the front differential when I had only the front end on ramps. It overfilled and caused the passenger axle seal to go bad. So now I’m replacing the seal right now. Don’t be like me..
brian.sestokas
Memphis, TN
From all of the bulletins and manuals, I see the Front differential is 75w-140, but the rear is 75w-85. I cannot find 75w85 in my area. Has anyone used 75w90 instead?
Yes, stick with full synthetic brand name. I use Mobil1.
brian.sestokas
Memphis, TN
I never go with anything not a full synthetic, but my main question is about the rear diff being ok to raise the viscosity from 75w85 to the 75w90. I know it's not a big jump, but just wondering if anyone has done this rise and has had no issues. This is my first change in the ST so I just want to make sure the 5-point rise won't mess up some sort of electronics in the system.
I think most of us use 75W90 synthetic in the rear because that's what is readily available.
Nunya
I'm using valvoline synthetic 75w90. I promise it's better than the magnetic mud that's going to come out of your diff.
f150ST
colorado
25 explorer ST
Ams oil has it directly on there web site. easy fill jugs too, very convenient. Expensive but they have very good products delivered to door. 75w 85 .
Rodeorowdy
Alaska
2020 Ford Explorer XLT
I’m about to do the first front differential fluid drain refillon my 2020 Ford Explorer XLT.
i’ve studied the photos of the front differential and it looks like if I lift up the front passenger side tire to access plugs and drain.
After I reinstall the drain plug, I would let the jack down as low as possible, so I could still get under there and use a jack stand for safety. Then refill with exactly 0.6 of a quart, which is 19.2 ounces.
My concern is, I won’t be able to CORRECTLY check the diff. level because it will still be jacked up slightly on the front passenger side.
But my thought is, it’s drained BEFORE I add 0.6 of a quart, Then I can lower the vehicle to level for several moments to let any excess drip out of the fill hole. Then lift it back up, install the fill plug and clean the area. Job done
Any thoughts would be greatly appreciated.
