Help! My gear selector dial will not move into gear and is stuck every morning.
Dania Beach, FL, USA
I started off scanning it and then it starts working all day long until the next morning, it does it again. I found the battery was shorting with high resistance, failed the test, so i replaced it. I reset all codes. The next morning the same thing, I replaced the brake pedel switch, same exact story, the next day, it was stuck again. I spoke with a Ford Master Tech, he told me the knobs go bad, I bought the correct one and installed it. Did n't need to load the software, I got lucky, it worked until the next morning. It is still doing it.
It seems it goes to sleep and it will not wake up the module that sees the brake pedal signal and tells the knob it can move.
Has anyone else experienced this problem?
Also, since I changed the battery, I now have a no pre-collision assist dash warning and the cruise control will not engage.
Desert South West
What error codes are you seeing?
mikecombs66
after I change the battery according to the isolation manual, it should’ve fixed it I confirmed the battery was shorting with high resistance and it was throwing off the cancer system, but what’s happening this vehicle falls asleep overnight and that system doesn’t wake up when I touch the starter to allow the shifter to move. It’s like it’s asleep. I’ve already replaced it with a new one and it was working perfectly until the next morning.
Desert South West
How long was it without power when you swapped batteries? If not very long then you may want to disconnect the battery for a few hours, then retry.
mikecombs66
It was only disconnected, maybe 45 minutes. I was told that there’s a way to drain all the modules by removing the leads and putting them together for 10 seconds and then putting the car back and there’s some sort of a reset procedure. Seems like that’s all I need. I saw that there’s a fuse that has a wake up fuse or something like that.
Desert South West
I would try that next, also if you have not already done so, recheck all the connections to the battery, even the one's you did not disconnect.
