Coolant changing color ?!
Andyville
Pennsylvania
2023 ST
Hey guys,
I’ve checked my coolant after a run yesterday and it looked orange-ish to me.
I looked it up on the forum here and someone said that it could be due the heat cycle, that it caused the discoloration. I thought it to be temporary too, so I let it sit overnight.
I know for a fact it came a bit low from the factory and I topped it off to level at the dealership. It’s been about a year now, but at either times the fluid was green before and after, until now.
Should I be concerned about this, or is this a normal thing that just happens overtime? It’d help to know if someone has experienced this before and how they dealt with it.
P.S.: I’ve attached yesterday’s post run pic and today’s, so you’ll see the difference when it was hot yesterday (above max level) and it was cool today (in between lines)
Thanks
A
Andyville
Pennsylvania
2023 ST
Can anyone advise?
Nashville, TN, USA
That looks normal to me. This is an overflow/expansion tank and it doesn’t really circulate the coolant thru there nearly as much as the radiator. I wouldn’t worry about it unless you wanted to do a coolant drain/refill just so you know what you’re working with in there. Also, remember to top off with the special Ford coolant not regular green coolant.
A
Andyville
Pennsylvania
2023 ST
Thanks for the reply, but what's the "special Ford coolant" referring to? I've used the motorcraft pre-diluted antifreeze coolant, something specific that the manual stated to use.
A
Andyville
Pennsylvania
2023 ST
Motorcraft WSS-M97B57-A2
Yup that’s it, the yellow one. Pretty sure it looks like it or it’s close enough.
Nashville, TN, USA
Use the stuff that @Stone17 linked to. Ford has been through several variations of coolant types/colors over the last 10 years or so, but the yellow stuff is the current version.
A
Andyville
Pennsylvania
2023 ST
I just confirmed. That's exactly what I have.
