ST number 2 with custom wheels
Not bad, definetly unique!
Midwest
Interesting... I read what they were and thought I wasn't going to like them but they look pretty good!
Hull, GA, USA
I always liked that wheel design. What wheel manufacturer did you use?
csnapp254
Livonia, MI
There is a shop here that specializes in fox body mustangs. He is a former designer at Ford Motor. I approached him with what I wanted to do, he took the specs I asked for made the CAD drawing and had his supplier manufacture them.
https://makers-garage.com/?srsltid=AfmBOopAb9xeXrN4lkl8RuTM39tHIHauD0IkRetDnlkH1llZ3hspCmKE
My head says GMC truck wheels.
I love larger versions of that wheel on Fox body cars…not sure it works on the ExST.
Nashville, TN, USA
As a current ‘93 Cobra owner, I approve. Definitively a unique setup!
Mollz
miami fl
23 st (diamond)
Looks awesome … they’d look good powder coated gloss black as well
Those look sweet, I love the look of OEM wheels. I did some thing similar on my first ST. I always liked the look of the factory 22's on the 13-14 edge sport so when I found a set already powdercoated in black, I had to get them. I had the hub bore opened up to fit the ExST because the second gen edge used a 63.4mm hub bore and our ST's use 70.5mm. I still have the wheels, when my 21" tires need replaced, I'm going to put new tires on the 22's and run them again.
Nascarbilly
Sacramento, CA
2025 Rapid Red Explorer ST
Those look sweet, I love the look of OEM wheels. I did some thing similar on my first ST. I always liked the look of the factory 22's on the 13-14 edge sport so when I found a set already powdercoated in black, I had the hub bore opened up to fit the ExST. I still have the wheels, when my 21" tires need replaced, I'm going to put new tires on the 22's and run them again.
View attachment 32128 View attachment 32129 View attachment 32130
@I Bleed Ford Blue:
@I Bleed Ford Blue: Yes I agree on using OEM FORD stuff. Silver powder coat would also work great with certain body color types like white, black or the red ST's.
I think these wheels would look good upsized to fit the explorers
The first gen edge had a 22 also and they have a 70.5 hub bore so they bolt right on our explorers
and the 2006-2010 explorers had a 20x8 wheel that would look good upsized to a 22
OP, definitely unique!
