Is the factory B&O "premium" sound system salvageable?
ImTheBrian
Hi All, first post so please be gentle =)
Just purchased a 2023 ST and I'm quite unimpressed with this B&O abomination. My 2020 Grand Cherokee sounded infinitely better in an older $20k cheaper vehicle (bone stock, not the upgraded system with the sub either) with nice defined highs and a nice thump at the bottom end.
Can this garbage heap of a stereo system be saved if I throw some quality components at it? I don't need ear-bleeding volume nor do I want to rattle windows 12 blocks away - I just want clean sound with some bottom end to it instead of the Fisher-Price audio mud experience I'm currently suffering through. I've read through a ton of audio threads on this forum before posting and I'm seeing a lot of mixed messages between the "good enough" and the "sound competition with money to blow" crowds.
So here's the million dollar series of questions: Is the culprit the really really horrible DSP tune from the factory, the 3rd world country level components, or a combination of the two? Can I put in quality drivers in the factory locations, continue to run them from the factory amp, have a custom 10" box built for an aftermarket sub and dedicated amp in the factory location for reasonable sounding results? Will that money be thrown away by the still horrible tune or will the infinitely better components step up to the plate and fill in the gaps (i.e. will the factory sound settings be so bad that it can't be helped without a 3rd party DSP to undo the work of Ford engineers without ears)? Does the factory install use any type of crossovers, or is everything full range with maybe a choke on the tweets and sub? I'm also curious about reports of the factory sub output ramping down as the volume increases - some say it's happening while others don't. I personally can't even tell if the factory sub is doing anything at all as the bass output of the entire system seems to come from mid-bass in the doors so I'm unable to determine - the "sub" frequency response must be absolutely terrible. If I tap into the sub input for a line-level converter for a dedicated amp, will it too be affected by this ramping (assuming it exists and is coming from the head unit and not the amp itself)? Will the noise cancelling and / or fake exhaust cause real problems?
I don't really want to gut the whole thing if I don't need to, but at the same time I can't stand what I'm currently stuck with. Ford should be embarrassed, I know I am. lol
I've had fords my entire adult life and about 20 years ago I started buying higher end vehicles with the best sound system ford had to offer in that vehicle. My 2010 explorer with the factory nav and primitive sync is infinitely better than the system in my 23 ST and my 23 mach 1. The 2010 has no DSP, just speakers, sub, and a factory amp and sounds about 10 times better. As time progresses, ford sound systems are getting worse. The mach system in my 17 mustang wasn't that great but it was better than the body odor system in the ST or the mach 1.
^^^ Agreed, the Sony system in my F150 is much better than the B&O system in my Exploder.
Mobile, Alabama
2025 Explorer ST 4WD
My wife and I have been through about 11 cars in the last 10 years. While the B&O with sub isn't the best, it ain't the worst by a long shot. On my 2019 PP2 Mustang, I went in and spent $4000 on JL everything. Speaker replacements included adding the preformed sub box in the trunk with an RF amp. Marginal improvement in sound. Way overspent.
For the normal person, these are fine, and my Edge ST had excellent bass. I put my 2025 in surround mode, increased the mids and bass some, and haven't looked back. If it ain't for you, it's time to visit the car stereo shop or Crutchfield. And BTW, I'm 48 and have been on car and AV forums since I was 20. People bitching about OEM sound has been a thing since then, and will continue to be a thing when we are dead. I say that, but these kids now are happy with an iPhone speaker for the TV viewing, where I have a 77" OLED and surround sound in my living room, LOL. They may care less than we do.
Kansas City
2025 Explorer Platinum V6
We recently traded in a 2026 Buick Enclave Avenir for our 2025 Explorer, and holy hell, the sound system is a significant downgrade. The Bose system in the Enclave was the best factory system I’ve ever heard.
I’ll be watching this thread for suggestions, and I also plan to call Crutchfield at some point…
Socal
My older 18 Explorer Sport had a better sound system as well, speakers werent cheap paper cone's either. Not sure why Ford decided to dropped that system.
Far as making this system better, changing the DSP and adding sound deadening, the sound deadening definitely helped on the bass for me with the stock sub
Most people say changing the audio EQ to Surround vs Stereo makes a difference, so maybe than can help?
Desert South West
I use my Bluetooth linked phone with a audio app that has a 11 band eq, also has adjustable preamp and bass settings, can set eq for each song or Album. Makes a huge difference.
What you just wrote is most of the problem…Bluetooth. Once you have trash in…you will always have trash out. Same applies to low bit rate wired streaming, satellite radio or any other low res source.
Socal
Agreed.
You want high quality stuff? Use USB drives with FLAC or other lossless formats. Or, plug in your phone directly USB via carplay/android auto and turn off the bluetooth audio streaming on your phone. If you're still streaming 192 kbps or MP3's, you're still lowering the quality.
Agreed.
Tidal wired in at 24 bit/192 kHz is as good as you’ll ever need. We do audio competitions at that level.
Desert South West
Tried USB drives, Blutooth sounds better, not a fan of android auto. Not sure if you can do any better with music from the 60's and 70's.
Sorry, but that is demonstrably false.
That Bluetooth sounds better. You take the same track in a high res/lossless format, play it through a wired connection and play it through a Bluetooth connection and the wired will measure and sound better.
Kansas City
Welp, this thread went off the rails.
The audio format is not the primary issue with the B&O system…
Desert South West
That's why I made a Comment about using my smart phone audio app to tweak the system.
