My almost 4K mileage new engine is throwing Evap codes P0456 and P0496 now what ?
MD
I dealing with evap codes which seems kinda early !!
Purge valve. Common problem.
South Carolina
Purge Valve. $70-$80 part, don’t buy from dealership and don’t buy a knockoff brand.
ButchsExplorerST
MD
If not the dealer where would you recommended?
BitViper
WeNoGottaRancho
Check the flappers in your fuel filler.. they sometimes stick open
ButchsExplorerST
MD
Thanks that was the first thing I did, so now the P0456 hasn't return only the P0496
ButchsExplorerST
MD
Engine recently replaced? Loose connection(s)?
I think I fixed all the loose connections , believe me their a lot after getting it back.
Rarely will I top off, but only use 93
Topping it off (overfilling), depending upon the amount and/or frequency, can destroy the purge valve. Octane rating is not germane to my comments.
