Film on windshield, nothing has worked!
USN_Ret.
Tucson
Hi all,
We have a new 25 Explorer ST, and ever since we've gotten her, there's a haze, dirt, film on the windshield, both in and out, that we can't get rid of.
We've tried alcohol, Sprayway glass cleaner, Dawn soap,etc., but it's still there.
The inside film is the worst, I have the feeling it might have been off gassing vinyl or similar, but it's REALLY annoying!!
Has anyone else seen and dealt with this before? If successful, what did you do?
At wits end,
Paul
St. Louis
0000 steel wool.
You can try comet and a blue kitchen scrubby pad on the outside. It takes a lot of water to rinse away the residue so don't try it inside unless you want to flood the interior.
Pennsylvania
2023 ST
Hi all,
At wits end,
Paul
In case you still haven't fix this, don't use the cheap stuff and use Bilt Hamber's Trace-less and thank me later https://bilthamber.com/product/trace-less/. If the problem is something that is not an issue with the glass itself, it'll work instantly.
Use any microfiber waffle towel, though I default to https://www.obsessedgarage.com/products/waffle-weave-glass-cleaning-towel anytime I have to do anything to glass.
Mobile, Alabama
2025 Explorer ST 4WD
Ive seen new cars do that, always wonder what was producing the haze lol.
I like Invisible Glass sprayed onto the towel, not the glass. I've done my 2025 front once, and it has been fine, but the back window is a PITA.
