Activate used FOB with Forescan?
chefron777
South Carolina
Hello All -bought a used, refurbished ST FOB for my 22 ST. I cannot get it programmed from all of the searches i have found on facebook forms and other goggle sites. If you know the exact way please let me know. BUT can you use Forescan to program the FOB? . I have the 2 Admin keys car came with (i just bought the 22 ST used with 40k miles) . Wanted to get a 3rd key for backup. I just cant get it to recognize for adding the 3rd no matter what i tried. thank you! Ron - SC
I don't think you can do it your self. I would check with a locksmith that does motor vehicle keys.
Nope, can’t use Forscan.
Massachusetts
2023 ST
You don't need ForScan. (nor is it possible to use ForScan anyway)
This method works below once you have two programmed keys in hand. You can program a 3rd and 4th key this way up to 4 max
How to program Ford Explorer (6th Gen) key fob yourself without additional / special tools
I would go into the vehicle settings menus and look for the Mykey setup menu. I forget how it's worded but one of the options there will show you how many keys are programmed to the vehicle. Look to verify that you don't already have 4 keys programmed (highly unlikely), in which it won't accept another one.
The above method using the programming slot works, although from what i remember the orientation of the key does matter. Took me a few tires to get it. I managed to program 2 additional keys for 4 total.
