Roof Trim Leaking Water
I had this leak on the driver side for about 3 months now.
Removed the Driver Side A pillar and other driver side trim.
Ran a water hose around the front of the windows shield until I see the water dripping.
Found out the water was leaking from the roof trim bracket.
Pry up on the front of the trim to disconnected it from the taps.
To get access to the 2 10mm bolts, you will need to drop the headliner. See Houston Speed Freaks Explorer ST Roof Rail Delete
All 4 was the gasket are hard like a rock.
I removed this gasket.
Add Black Silicone around all the bolt holes.
Reinstall.
Very helpful thread. Great writeup!
Instead of silicone use butyl rope. It’s a much better tool for that job. Silicone will delaminate over time especially off smooth surfaces like car paint. Butyl is what they glue your windshield in with…it’s not going anywhere. I sealed all of those holes with it on my car when I did the roof rail delete.
Stone17
Damn. I have that stuff in my garage. Next time.
kylioST
sandy, Oregon
How did you know it was leaking Could you visually see it inside? I just washed my car for the first time, new owner of a 2022 explore ST and saw sum puddling on the passenger floormats. wasn't wet anywhere on the celling so I don't know if it was my PTSD from my 2021 grand Cherokee, I traded in that had Major leaking issues lol LOVE my explorer
Your issue isn't the roof rails leaking, Your issue is the trim panel over the battery under the hood on the passenger side, If that panel is not snapped in correctly at the base of the windshield, water will get in and puddle in the passenger footwell.
That ^^ or a sunroof drain hose popped off.
kylioST
sandy, Oregon
Just checked it and Definity was not attached properly thanks for the reply!!
How do I locate this ?
Most likely it was the battery cover. Dry out your interior first and make sure it doesn't get wet again before you go digging around for the drain hose.
kylioST
sandy, Oregon
Copy that!!! thanks again
Stone17
Pull the interior a pillar trim off and maybe remove the glove box. Spray roof rail and windows with water. Look for leaks on the inside.
When my roof rail trim was leaking. The water would travel down the a pillar into the dash.
Check this area around the window shield. The gasket may need to be pushed back in (just under the windshield wiper)
See picture.
sandy, Oregon
Would any of you guys know if it would be covered under warranty to fix the leak puddleing up on my floor mats just an update the leak happened again when I washed it called the dealership and they said they didn't kno if it would be covered, bought the st with 49000 miles and it would be my 3rd week of ownership not happy at all..
What year? Did you check your sunroof drains and push down the cowl to make sure it was fully on?
Stone17
Pull both A Pillar off and check for water leaking.
sandy, Oregon
2022 ,I did push down the cowl and it did sound like it snaped into place. It rained today here in the PNW and no water on the floor mats. I have to check with the hose this weekend.
