Lowered Cars /W Spacers And Adding -.5 Deg To Rear...
BitViper
BitViper
WeNoGottaRancho
Thread Starter #21
So.. my mechanic said my upper control ar was not adjustable...
So I thought he's just avoiding a job... So I went to and adjustment shop... when in doubt.. go to a specialist....
He showed me my upper control arm.. and there is no way it could be adjusted... It was just a single bolt holding in the upper control arm...
BUT.. its seems that some.. but not all Explorers DO come with adjustable upper control arm BOLTS... I'm guessing 2WD's or some other random thing that happens at the Ford assembly factory...
To remedy the problem you'll need one of these (or equivalent) ... Link to Part ... to replace the M16x97mm OEM NON ADJUSTABLE bolt
Hey Unbroken... can you find a source for these I cant seem to find a source yet?
<<EDIT>>
I did find a place.. recommended All Tire Supply by the Northstar site (they have a "Where To Buy" link) .. they didn't carry the part.. but could order it.. $139.90 shipped to Ca for 15 bucks....
Might as well add the installation instructions... PDF Installation Instructions
<<EDIT>>
Your mechanic is wrong. Period. It’s not even negotiable. The UCA bolt at the frame is a slotted connection to adjust rear camber. It’s not an adjustment bolt…which is called an eccentric…the bolt hole itself is slotted.
Anyone that tells you anything different is a fool.
And again…that camber kit mounts INTO the factory adjustment slot. I don’t know how to be any more clear on this.
BitViper
BitViper
WeNoGottaRancho
Thread Starter #23
I'm not doubting you.. I'm just relaying what folks who do this for a living are telling me.. lol
Question 1 - but what holds.. the bolt from shifting... Seems to me that by just making it F'ing tight it could slip.. which the cam in the kit addresses...
Question 2 ... Are there some sort of "keepers".. My experience tells me that things in slots eventually move if not limited by something...
"that camber kit mounts INTO the factory adjustment slot ".. I'm thinking that's a good thing....right? The cam will keep the bolt securely in place..
So worse case ... adding the kit will make the system "Overbuilt".. I can live with that
<<EDIT>>
Your guy is wrong. That bolt is the adjustment for camber. The cam bolt does nothing because it just goes to the stock location so it doesn’t change that at all.
Well the guy that does it for a living is wrong.
#1: it holds it just fine, that’s how it works for every other vehicle and the other adjustments for alignment
#2: Dont know what you mean by “keepers”, the bolt holds just fine, I don’t think you understand the way it works.
With that bolt you’re not overbuilding it at all, you’re unnecessarily replacing a bolt that does its job just fine, nothing will do it better because there’s nothing better for it to do.
Slotted eccentric holes have been used on a variety of makes of vehicles for decades, including this one. No offense intended, but your Alignment Tech is absolutely wrong. Perhaps he needs to brush up on things. Go pull the nut off and take a look.
Save your money on the cam kit. These too, have been available for years and only make money for the shop that sells and installs them.They advertise making things easier. As a Certified Tech, having done thousands of alignments, I thought they simply got in the way.
BitViper
BitViper
WeNoGottaRancho
Thread Starter #27
Ha.. No offence taken.... Just trying to get things done....
Lubbock texas
2021 ST carbonized grey metallic w/black leather
you will learn not to debate with unbroken. he knows his stuff from all the writings that he has done. if you have any Qs he will more than likely have the answers....
I have been to two shops this week (Ford Dealer and Custom shop) both saying nearly the same. I am not doubting anything being said here about the adjustment but just don’t understand how some make it seem so easy yet after showing people the pictures , can’t get anywhere near the numbers.
Frustrated to say the least. If ther is anyone in the tampa area that has a guru, please share.
, custom shop pic 1 after second visit and Ford second pic.
I'm not telling you that you will get it all the way to -.5, but there is at least a degree and a half in that adjustment from side to side. Sadly, if these guys have any real (read quality, perhaps expensive) alignment equipment they typically have picture diagrams that show how to make the adjustment.
Take the picture that Unbroken provided and show it to the Tech, and he'll slap his forehead and say how could I have been so foolish.
I have taken the photo of the Ford print out to both. Ford told me the stock setting was .5-.8 degree adjustment available from where it was factory (acknowledged the ability to adjust). Custom place , no input other than more movement but completely uneven settings
Obviously we can't see what the Tech is doing, but if he'll lift the rear end and let the wheels hang unloaded and perhaps use a bar between the frame and knuckle extension, he'll get the very maximum the slot has to offer.
The amount of movement that is available in this adjustment is typically what is needed to bring it to specs at an OE height. You lose some of that range when the car sits lower.
I can't tell you how many times I have used a die grinder on the ellipse hole to get that little extra bit of range I wanted. Chances are, if you max it out as is, it will be close enough.
BitViper
BitViper
WeNoGottaRancho
Thread Starter #34
I've noticed.... didnt think I was "Debating" but asking questions... given two pieces of conflicting bits information (from "Experts").. left me still trying to get things done... I never said he was wrong... only pointed out that I was getting conflicting information
“In the noise of conflicting wisdom, I listen not for the loudest voice, but for the one that makes sense when the echo fades.”
BitViper
BitViper
WeNoGottaRancho
Thread Starter #35
JFam... question just for my own gratification.. do you know if they ACTUALLY LOOKED or just looked at the UCA saw the bolt .. which I'm guessing hides the slot.. and just gave up.
If you havent noticed ..UNBROKEN..is emphatic about this....
In my case I don't know if the actually removed the bolt to see if an adjustment could be made or just saw a single bolt with nothing "supporting" that the bolt was adjustable...
The service manager of Ford said they utilized it however based on where it was set pre alignment from factory, they were only left with about half of the remaining adjustment. I don't have any input from the custom shop but did pull out the printout showing them and left it in the vehicle. I wished that someone in my area knew of a guy that is passionate about getting something completely dialed to the best of their ability.
BitViper
BitViper
WeNoGottaRancho
Thread Starter #37
Well looking at the image (UNBROKENS.).. there is only so much adjustment available anyway...assuming that the OEM position of the bolt is near the center of the slot...
But to be clear... did/were they able to make some adjustment.. but not as much as you wanted or none at all
California
#38
Anybody have before and after shots of their car Lowered on H&R's and wheel spacers without the -.5 deg adjustments..
Or shots of anyone who hasn't made the adjustment and just lowered their car used spacers and didn't?
Thanks in advance..
-Aaron
I'm also looking for anyone who has done the -5 degrees at the rear have the alignment printout.
BitViper
BitViper
WeNoGottaRancho
Thread Starter #39
hey CombaytVet.. are your headlights smoked.. Aftermarket?
Combatvet
