Thread Starter
      	Thread Starter
					So.. my mechanic said my upper control ar was not adjustable...
So I thought he's just avoiding a job... So I went to and adjustment shop... when in doubt.. go to a specialist....
He showed me my upper control arm.. and there is no way it could be adjusted... It was just a single bolt holding in the upper control arm...
BUT.. its seems that some.. but not all Explorers DO come with adjustable upper control arm BOLTS... I'm guessing 2WD's or some other random thing that happens at the Ford assembly factory...
To remedy the problem you'll need one of these (or equivalent) ... Link to Part ... to replace the M16x97mm OEM NON ADJUSTABLE bolt
Hey Unbroken... can you find a source for these I cant seem to find a source yet?
<<EDIT>>
I did find a place.. recommended All Tire Supply by the Northstar site (they have a "Where To Buy" link) .. they didn't carry the part.. but could order it.. $139.90 shipped to Ca for 15 bucks....
Might as well add the installation instructions... PDF Installation Instructions
<<EDIT>>
