Time Frame on Replacing Springs
Danno1
CT
Hi all
I'm having a shop install the Eibach springs. I know the fronts are longer to install with the struts. What time would all 4 take?
Working with my mechanic, we did it in an hour and a half. The rear springs are really easy.
What your shop bills in labor hours and how long it actually takes are two different things.
D
Danno1
CT
Considering they are legit. It would be the actual work hours.
The other thing is I know they have the hydraulic compressor at their other location because this garage is too small to mount the unit on the wall. There're going to use the manual tool they have IF they can.
D
Danno1
CT
Got it done. 450.00 dollars later. But I'm happy with the results.
Southern New Jersey
Shop will usually Charge between $400 - $750 to do the install and you have to get it aligned after.
D
Danno1
CT
Wow. Thought 450 was alot. Also Getting an alignment in 2 weeks.
BTW...which brand of springs gives a more factory rake?
Seems the Eibach has a slight rake.
Southern New Jersey
I like the rake the Eibach give very slight rake.
D
Danno1
CT
Very slight
From what I’ve seen, Steeda and Eibach maintain the factory rake. H&R levels out the vehicle with the ground so there is more rake.
I’ve had Steeda and Eibach on my St. the Steeda have a little more rake than the Eibachs while the Eibachs are a bit lower with a little less rake than the Steeda.
D
Danno1
CT
In order to get more "rake", would it be possible to place say a piece of flat stock, maybe 1/2 " in the base of the rear spring mounts?
That would decrease the rake. Rake is the downward slope of the rear of the vehicle.
D
Danno1
CT
Wouldn't that mean raising the rear it would keep the nose lower than the rear? That's my impression of a "rake"?
Anyway would the flat stock under the rear springs work?
I was thinking about the roof line.
D
Danno1
CT
Lol. I'm thinking just a slight raise in the rear to give a little more slope towards the front
Well, they do it on trucks to lift them so I don’t see why it wouldn’t work.
D
Danno1
CT
Thread Starter #18
IF I did it at home instead of bringing it back to where they installed the Eibachs, I would need to get a coil spring clamp? Or any other way?
You can’t put a flat plate under either end of a the coils.
D
Danno1
CT
Thread Starter #20
Oh well, got to listen to the ST Guru. I can live with it just fine as is. Still looks better than stock
