Vibrating… North of 67MPh
AG1
NJ
2024 Explorer
I’ve got a 2024 and have experienced a slight variation at speeds above 67 MPH or thereabouts
is this tire or drive line ?
3 dealership have told me it’s normal
not normal after paying almost 60k for the car
Any Suggestions?
Combatvet
Most likely a tire, but do you have lane keep assist on the '24? I'm just saying, maybe?
A
AG1
NJ
2024 Explorer
Vehicle is equipped with lane assist, but it is deactivated even one of the dealers checked and confirmed it is deactivated
Combatvet
Most likely a flaw/defect in one or more of the tires, could be a lost weight issue, hard to tell without driving it. If you had any of the suspension parts modified, I'd trace that, if it's stock, man you got your hands full. Check every bolt.
Any Suggestions?
Have the tires balanced. Sometimes the foam inside of the tire becomes dislodged and needs to be removed, that’ll be apparent with a balancing.
Desert South West
Where do you sense it? Steering wheel, seats, foot pedals? You could try rotating your tires.
A
AG1
NJ
2024 Explorer
Doesn’t feel like it is tire related … feels more centered like drive train
A
AG1
NJ
2024 Explorer
All stock… no mods seems to be more centralized like a drive shaft? But I would guess the vibration would be obvious at lower speeds?
Thank You For Your Service!
Desert South West
I had a similar problem with a 2004 Explorer 4x4 (noise only cut in at highway speeds), turned out to be a bad rear wheel bearing....
Honolulu, HI, USA
The original tires on my 2020 came with foam filled tires that vibrated at higher speeds and got worse as the foam innercaot (for making the tires quieter) disintegrated. No rpoblem after all the iiner foam liner was removed and tires reblanced.
