Red Lens Rear Reflector Bumper Replacements
Boyd
Tennessee
I just installed a set of these. Both me and the Chickadee like em. Only thing I'm a little disappointed about is the shift from dim to bright when braking isn't a very big shift. Especially with those killer bright LEDs from the factory.
Wiring: I'm pretty comfortable with wiring. Even a schematics manual wouldn't hep with the ST because all the wiring back there is either black or black w/ white stripe. Here's how I did it on the '21:
I used a trim tool to pop out the stock reflector. Used some really long tie-wraps and some wire to fish the new wires up thru the bumper to the taillight.
There's 4 wires that need to be spliced in. 1 ground, then 1 power for each function: tail light, brake light, T/S light.
First, there's a single ground wire coming off each of the 3 lights back there and spliced together. So that identifies ground. This was the first connection I wired up so I could test the others as I worked along.
2nd, there's only 2 wires coming off the amber T/S bulb. One is the ground, the other is your 12vdc+. So that's power for T/S.
3rd, there's 3 wires coming off the led plug. All 3 are black w/ white stripe. One goes to the ground splice. The other 2 are power for a) tail light (dim), and b) brake light (bright). I'm cutting and splicing the wiring, so it was no big deal to cut one of the wires, temp connect one wire from the new light. Turn on your headlights... if it lights up, you found the power wire for the tail light. If it doesnt, you found the wire for the brake light.
I made my connections by cutting the individual ST wire and splicing in with solder and heatshrink. I dont trust those t-connectors or 3M spice-taps. I'm an aircraft mechanic, and there's no way I'd trust those plastic things.
Anyways, cheap mod that looks cool, brightens up the back end of the ST. Oh, and the turn signal function of the new LED is sequential. Chickadee is happy. :cool:
JScottS
Campobello, SC, USA
Just curious if anyone found out if these also still act as reflectors when the car is parked (not powered)? Thanks and thanks for the pictures and descriptions.
Central Cal
They do not.
RAYJAY
Union Dale Pa
2021 explorer limited
has any one hooked them up to the wiring for the towing harness ?
Central Cal
I think if you do the Explorer will think you have a trailer hooked up.
23 Explorer ST
I have the Diode Dynamic trailer hitch light plugged directly into my trailer harness on my 2023 ST and it does not detect a trailer.
Now on my 2024 F-150 Lariat it will show a trailer connected.
RAYJAY
Union Dale Pa
#27
that was what i was wondering ? on the ranger you needed a factory brake controller, and could not plug in any thing back there,
RAYJAY
Union Dale Pa
will be doping a test... ordered a set of lights and will tap int the trailer harness...
23 Explorer ST
Keep us informed what you find. Hopefully it works for you.
Colorado Springs
21 Explorer ST
#30
I was successful wiring as per the photos. However, no sequential turns, just regular. I have changed my turns to be associated with the red brake lights though, so maybe this is the cause. I'm not mad. I like the flash anyways.
Jetiemann
Houston
I would rather have these lights be additional reverse lights or both with new dual LED technology. Anyone else?
Colorado Springs
21 Explorer ST
#32
This is a great idea. We have some smart folks on this forum, and I'm sure someone can make em!
Bebbeb77
Saudi Arabia
Explorer ST
#33
Hello All
BigSarge
#34
I wanted to weigh in on this ... I bought my ST in December 2024, bought these lights in January 2025 and installed them in March 2025... it is now July 2025, only 4 months later after install, and the driver's side has a seal issue with condensation inside and is now fading out. So my assessment is these are trash and won't last long. They look awesome when installed and working ... but until the Chinese figure out how to do a quality seal, I'm not up for replacing these 3x per year.
#35
A thin layer of silicone around the seal helps with this. They should be sealed from the start but they aren’t.
K. Black
Queens, NY
2023 Explorer XLT
#36
I did see them on a 2023ish explorer and they looked fantastic just yours. Great job. I’ve been eyeing them on eBay for awhile.
Canby, OR
So I decided to grab a set of these. I’m trying to get the OEM lenses out but I’m having a hard time! I don’t want to snap off the mounting tabs so I can reuse them if needed. How do you get up behind them to pop them out? Do I need to drop the bottom piece?
BigSarge
#38
Here's a close-up for you of the back of the OEM reflector. Just apply pressure up and out at the same time. I didn't snap either one ... in fact, on both sides I popped one end up and used a trim remover tool to slowly pull and the other end popped out.
Canby, OR
So are you doing this from the back side or from the front?
BigSarge
#40
Use a 90-degree needle nose pilers on the end with the two tabs to squeeze ... work it out slowly from the back, it will budge
Use the trim tool from the front on the other end and just pry slowly ... it will pop out (at least mine did) without breaking.
