Blind Spot and Cross Traffic Faults
jweakley
Tulsa, OK, USA
My 2021 Explorer ST had the passenger side outside mirror replaced several years ago due to pellet gun damage. Now I am getting a blind spot and cross traffic fault detection, and the dealership is telling me that the only fix is to replace the entire outer unit and contents at a cost of ~$2,100. Is this my only option?
Desert South West
I could be wrong, but I think that sensor is in the rear tail light, water intrusion? Intermittent fault?
jweakley
jweakley
Tulsa, OK, USA
The dealership told me that it was because the wires in the passenger side mirror became disconnected, and the only fix was to replace the entire mirror assembly.
You could save some money if you find a mirror on Ebay.
jweakley
jweakley
Tulsa, OK, USA
Perhaps I wasn’t clear. The mirror was replaced, and the system worked for a year or so. Now I am getting a fault message, and the dealership says the entire mirror assembly has to be replaced. I’m looking for a fix that costs less that $2,100+.
If the wires became disconnected. Just reconnect them? It's a simple matter to pull the door card and access side mirror.
Novtec1
Lawton, OK
I been getting this error for the past week. Only had the Vehicle for 2, started after i washed it. Have a appointment next week to find out what the issue is.
Desert South West
So the mirror glass was replaced, now you have an internal fault. Sounds like you have nothing to loose, I would watch a few YouTube videos then try to disassemble and repair it. You can also buy and install a used assembly and use Forscan to cal the camera. A new unit from ford is about 1/2 that price, not too difficult to install. Another option would be a auto body repair shop.
