It took me many times for it to finally take or keep the command of me wanting it off. At one point I inserted the seatbelt and unbuckled it a lot more than just the (4) times is tells you to do and then it finally worked.
On the 25' I have not found anything I wanted to disable or turn off that has not been a problem. The software system is not correct. I keep dogging on Ford and they deserve every bit of it. They release vehicle after vehicle with problems right out of the factory. I've been a Ford guy my entire life but I'm at the point that I'm not so sure I will buy another Ford. I'm tired off their repeated poor quality and warranty issues.
Only way that fixed it.
Software is a pain in the arse and can be expensive.
Then got to deal with that clunk noise at low speeds. They don’t hear it and even told them to stick your ear on the struts. The mechanical stuff really pisses me off since these parts have been around for years. Still, they manage to screw up. Then when I get this squared away, have to see if they can fix the out of alignment moonroof shade without screwing up the interior.
Never ends.
 - Show All
