New Warning Display?
Suprawill1
Hey All,
I just had a new pop up screen come up saying "Check Manual". After I cleared it with the "OK" button, there was an open wrench icon on the right side of the gauge cluster.
During this, I found I had almost zero acceleration. Even when the transmission downshifted, the RPMs went up but almost no/very little acceleration power. When I got home,
I did a key cycle. After restarting, the icon went away but I didn't drive to see if the power was back. This all started after I did a 20 - 95 full throttle acceleration.
I went to the PDF manual but couldn't find anything relative. Any ideas?
Thanks
Desert South West
Hey All,
Thanks
Have you scanned for error codes? even if it reset, it should still be listed.
Hey All,
Thanks
See if it threw a code and pull it.
Suprawill1
Suprawill1
Thanks, I'll check for a code on that. The CEL was already on and I had yet to check for the previous code. Don't know if it's affiliated or not but if it isn't, I might see 2 codes.
Do you have downpipes?
texas
I've had that happen before and it ended up being a P0234 overboost condition. I ended up clearing the code and no issues after that.
Suprawill1
Suprawill1
I have 3 codes and that is one of them.
The other 2 are:
P0056 Heated Exhaust Oxygen Sensor - Heater Control Circuit - Bank 2 Sensor 2
P2098 Post Catalyst Fuel Trim - System Too Lean - Bank 2
I guess these caused the computer to go into limp mode until I did the key cycle.
Suprawill1
Suprawill1
You didn’t put the defoulers on did you?
Yes, put the defoulers in on installation. That was last year and 23,000 miles ago. CEL didn't show up for months after. Don't know if that's the culprit but if it is, it took over a half year to show up.
You need the defoulers. if you didn’t put them on that would give you those codes. Try clearing them and see if they come back. Maybe check to make sure everything looks okay under there?
