TPMS sensor reset
Bakerjaa1
Milwaukee, WI, USA
I recently took my 2022 to a Ford dealer to have two valve stems replaced due my negligence in putting metal caps on them and subsequently they fused metal to metal. Made a 3:30 appointment friday before Labor Day and an hour and a half later they informed me that could not reset the sensors and wondered if I could wait longer to have an experienced tech look at. Waited an another 30 minutes and they pulled my car up and said ready to go. Drove off and flipped to the tire pressure screen and they were reading from 36 to 80 PSI. Not fixed and before I came in to replace the valve stems they were working perfectly. Of course they were closed as i called back and won’t be open until Tuesday . I asked about who was going to correct their error or if I need to find another dealer . The service advisor did not have a good answer. Any thoughts on this ? Saw some videos on reset . Actually got it into learning mode and the only sensor reading is the left front. The rest just show blanks on the other wheels.
Punta Gorda, FL, USA
I just went through this issue with my 2022. I got tired of trying to make the sensors work properly so I got on Amazon and bought a set of 4 315 Mhz sensors. 60 bucks. Bought my own sensor reset tool for 13 bucks.
put the car int relearn by pushing and releasing brake pedal once then push the start button 5 times. Push brake pedal one more time then push start button 6 times and it will go into learn mode with a pop up screen verifying it. Take one new sensor point the relearn tool at it and the horn will honk and screen will tell you it was successful that by the way was the LF wheel. Then the screen tells you next and you repeat which will be RF wheel. Continue to to RR then to LR. Then the screen will show successful. mark the sensor position on the sensor as you go along with a piece of tape with position LF,RF,RR,LR. Take the vehicle to a good tire store have them replace the sensors in the position you have marked. Drive vehicle and everything pops up in the correct position and you’re good to go. Worked perfect for me. Good luck! Jim
Aleydín
2017 Explorer
Very educational! I appreciate you!
This past mother's Day, is when the tire pressure sensor fault light came on.
I have a 2017.
Without taking the Explorer to the mechanic, is it possible and if so, how would I find out, what the problem is... a battery voltage of the sensor, reprogramming the sensor or resetting the system? (From some readings)
Also, what is "relearn tool?
How did you know what sensors to purchase?
And the sensors still need to be installed at the tire shop?
Thanks
EDWYER
You can find these on Amazon, just do some searching.
Robpacific
Los Angeles, CA, USA
Just went through this and posting for anyone with a similar experience.
TPMS sensor died. Ordered replacement “pre-programmed” off Amazon set of 4 for $50.
installed the new TPMS and did the flash your emergency lights three times to relearn procedure. Aired down each tire but it wouldn’t pickup the new one.
ordered a $150 tpms autel service tool off Amazon. It diagnosed that the sensor ID was not the one assigned in the BCM. Used the tool to scan and program the sensors — good to go.
also I think it said the 2019-2023 are 315mhz and the newer models use 414mh or something like that.
Your preprogrammed sensor still needs to be flashed to the ecu which seems weird because on my 2017 mustang it was plug and play — drive away.
Hope it helps someone. If you use a tire shop they should be doing this for you.
also I think it said the 2019-2023 are 33mhz and the newer models use 414mh or something like that.
Most of that is incorrect. The 20-24 cars will auto-learn any 315 MHz sensor. No tools or procedures are needed.
Must be lucky.
Drove it for a week it didn't work. Tried the 3 pushes on hazard lights + air down it didn't recognize it.
Tool diagnosed the mismatched sensor code and flashed it -- DONE.
Must be lucky.
Luck has nothing to do with it. That’s how a properly functioning car works. I recently put a whole new, never mounted set of wheels, tires and sensors on my car…within 1/4 mile everything was function as it should. Also just talked someone through this last night when they swapped on oem 21’s for their oem 20’s…less than a mile and his car was fine. The car is designed to function this way.
And yet, mine did not. Actually, since then the other rear sensor has died too, and I had to go through the same process again this weekend -- so at least I got my money's worth out of my TPMS tool and tire machine.
Tompei78
Long Beach
Do you mind sharing which TPMS sensors you got? I have 2 which most likely are broken / ran out of juice and I need to get the set of 4.
You shouldn’t need a programming tool. Any 315Mhz sensor will work as long as the battery is good. The vehicle will pick up the sensor automatically. There’s no need for a $200 programming tool.
And yet mine did not — so maybe the answer is don’t buy the sensors I bought. Then again that TPMS tool was $150 when I bought it and the sensors were $50 for 4. $200 still cheaper than $60 per sensor or whatever the OE sensors cost. All 4 of mine went bad within a month of each other. Glad I replaced because last week had a nail in tire while on family vacation trip.
Could be! That’s why I chose to go with TPMSDirect.com. $68 for 4 metal stem sensors that match my rims and guaranteed to work.
dsga1
Colorado
holy smokes... this awesome. thanks for posting the procedure. -GA
BitViper
WeNoGottaRancho
So.... You're saying a tool ISNT required? That would be nice!
What is the process/steps for adding in new TPMS.. Im in the same boat just got a set of 2025 wheels w/o sensors.. bought some replacements and need to install them.
BitViper
WeNoGottaRancho
I did find this
To perform a tool-free TPMS relearn on a 2021 Ford Explorer, ensure all tires are inflated to their recommended pressure, then turn the ignition on without starting the engine and press the hazard light switch six times within 10 seconds to enter train mode. The instrument cluster will prompt for the left front tire, so you must release air until the horn honks. Continue this process for the other tires in a clockwise direction, and the display will confirm "Training Complete" when finished.
Step-by-Step Relearn Procedure
  1. 1. Check Tire Pressure:
    Confirm all tires are inflated to the manufacturer's recommended pressure, which can be found on the sticker inside the driver's side doorjamb.
  2. 2. Enter Train Mode:
    With the key in the "On" position (without starting the engine), press the hazard light switch six to seven times within 10 seconds.
  3. 3. Confirm Readiness:
    The horn will beep once to confirm that the vehicle is in training mode, and the instrument cluster will display a message to "Train LF Tire" (Left Front).
  4. 4. Train Left Front Tire:
    Go to the left front tire and release air from the valve stem until the horn honks again.
  5. 5. Train Other Tires:
    Move to the right front tire and repeat the process of releasing air until the horn honks.
  6. 6. Complete the Cycle:
    Continue this for the right rear and then the left rear tire, in a clockwise direction.
  7. 7. Training Complete:
    After all four tires have been trained, the display will show a message indicating that the training is complete.
  8. 8. Re-Inflate Tires:
    If you over-released air while training, it's crucial to re-inflate all tires to their correct recommended pressure.
None of this is necessary! Put the new TPMS sensors in, drive an eighth of a mile and they will learn automatically. As long as they are 315 Mhz and the batteries are all good.
BitViper
WeNoGottaRancho
Oh that s cool... So the "system" knows Left from right front from rear... too cool!
Hmmmm a wrinkle...
The 2021 Ford Explorer ST has a "self-learning" TPMS that can automatically recognize the location of sensors after a tire rotation or replacement. However, a manual relearn or "training" procedure is often required for a full reset or to pair new sensors. Simply driving the vehicle is usually enough to reset the system after a tire rotation, but if you install new sensors or the light remains on, a specific sequence must be performed.
and
If the system does not reset on its own or if you have installed new TPMS sensors, you must manually put the vehicle into training mode. This can be done using the hazard lights.
Still seems straight forward...
