Updated FORScan sheet for 2020-24 Ford Explorer (All Trims)
Charlotte, NC
2022 Explorer Limited
#61
Is Global Windows open/close not an option in these year models? 2022 explorer limited. If so is there a spreadsheet for it?
Nightshade
Nightshade
Firefighter
Alberta, Canada
Thread Starter #62
Just thought I'd update this thread by stating I've refreshed the 2020+ Explorer FORScan spreasheet to include the years the changes would work with.
Nightshade
Nightshade
Firefighter
Alberta, Canada
Thread Starter #63
Charlotte, NC
#64
Nightshade,
Thank you for what you do and you experience. With further searching I was able to find an answer to my question on another forum. I want to respectful to you and this forum so I will not post it here unless I was granted permission. Also, it's not mine.
Nightshade
Nightshade
Firefighter
Alberta, Canada
Thread Starter #65
Nightshade,
You’re welcome! It’s perfectly fine. I will be updating the 2020-2024 Explorer spreadsheet next week, global windows open/close will be added to it along with a few more changes.
AvadaK
Charlotte
2020 Explorer Platinum
#66
Nightshade,
I thank you for your work, helping us modify our Explorer.
I have an Explorer Platinum and I’ve seen talks about Glare Free/Matrix lighting for Ford vehicles equipped with projector head beams/adaptive headlamps. Especially for the F150, there were forscan codes to enable it.
if it’s not too much to ask, is possible that you can look into seeing if we can enable the glare free free lighting in your next spreadsheet release. I read that it’s toggled off out of the factory but it’s toggled on in vehicles outside of the US. This was due to Matrix/Glare Free lighting not being legal at that time, but it’s legal in the US now. I would greatly appreciate it.
Nightshade
Nightshade
Firefighter
Alberta, Canada
Thread Starter #67
Nightshade,
Glad to be of help! You are correct however I can definitely look into this for you. But please be aware, Glare-free feature was removed/deleted for the 2024+ F-150s. If your Explorer Platinum is 2020-2024 years, there is a high chance it will work once I can look into the values?
AvadaK
Charlotte
#68
Good morning Nightshade,
Yes, I do. I have a 2020 Ford Explorer Platinum.
Thank you so much!
Nightshade
Nightshade
Firefighter
Alberta, Canada
Thread Starter #69
Thank you so much!
I will look into this for you very soon and send you a PM of the values that you can try!
Massachusetts
2023 ST
#70
@BrooseDaMoose is correct. You can change it on 2025+ Explorers but for 2020-2024, you can’t. This is because the stalk being used in these models is outdated and there’s no values to change for it.
2021+ F-150s you can change the number of turn signals because of the updated stalk.
That's a bummer. Just came to this thread to look specifically for this feature.
The previous gen Explorers will allow this, so curious why Ford would take a step backwards on the turn signal stalk in the 20-24's.
Another feature I am looking for. Is it possible to have the white DRL bar enabled while in Park (with engine running) for the '20-24's?
Nightshade
Nightshade
Firefighter
Alberta, Canada
Thread Starter #71
I honestly have no idea, why Ford does what they do, is always unexpected like removing features on newer years too.
White DRL enabled while in park, only thing you can do this is via Mode 2 (marker mode) on headlight knob. Mode 3 (auto) during the day, will shut it off and during the night, will remain with low beams on.
bigspoon86
arizona
2020 explorer st
#72
I'm not familiar with forscan is there somewhere i can get a tutorial on or is there anyone in Arizona who can help me out with it
Colorado
Is there an option to change the battery from h6 to h8? 20-24 explorer. I know I had to do it on my 16.
#74
Go to the Forscan website. Just make sure you know how to use it and exactly what you’re doing before trying to use it to make changes.
lexington, ky
Thank you for this! I need a little help though…
I want to correct the tire circumference for my 2022 Explorer in FORScan due to new 305/40/22 tires (31.6” diameter, 99.2” circumference, 638 rev/mile). I’m editing 726-15-01 and 726-15-02. Converted 99.2” to ~2520 mm (0x09D8 hex), and plan to input 09D8 in both addresses. Can anyone confirm if this placement and value are correct? Screenshots attached for reference. Thanks!”
Let me know if you need further clarification! IMG_8851.png IMG_3DCC1BDD-7D73-4620-8CCD-1C94D9D0934A.jpeg
Combatvet
I'm in the same boat, there are a couple of youtube videos that I found helpful.
Jessup, MD, USA
#77
Is there a way to view the front camera at higher speeds? Like up to 10 mph?
Toronto, ON, Canada
#78
Removes "Full View Not Available" message in rear camera view.
(Allows cams in motion at any speed without black box in middle)
APIM 7D0-02-02 xxx*xxxxxx--If your current value is 0 then change to 1, 2 change to 3, 4 change to 5, 6 change to 7
Note: reset APIM after the change
Massachusetts
2023 ST
#79
Is there any way to enable the 360 camera feature on the 360 delete credit cars?
My '23 has the credit. However, it has the cameras in the mirrors, and in the grill. I see the wiring harness for the grill camera in place and connected. I also see an option in ForScan for "360 camera" enable and disable. Mine is set to disable. I know i would need to buy the radio panel with the front cam button as mine is a blank.
Is there a module associated with the 360 camera? If so, where does it reside? Has anyone successfully enabled it yet?
Chicago, IL
Below is the link to the updated FORScan changes that is currently available for our 2020+ Ford Explorer and applies to all trims for those who don't have an ST. This one is for us, which helps compile all into one.
Keep in mind that the sheet will be updated by @powerboatr and @Nightshade (myself). If you're interested in something that isn't on the sheet yet, just reach out to myself or @powerboatr or comment on this thread.
LINK: https://docs.google.com/spreadsheet...ukfkgBqYkDE2w8imywaNF8VJF8/edit#gid=671029316
I was able to disable double honk and enable bambi mode just fine. What I am really interested in is changing the heated steering wheel temperature. My wheel seems to barely get warm and I want to see what the settings are of it in forscan. However, I was unable to locate it within forscan. Would you have any insight on where these settings are?
This link shows someone finding it for an F-150, not sure if it helps:
https://www.f150lightningforum.com/forum/threads/heated-steering-temperature-adjustable.19868/
@Nightshade @powerboatr
