A/C on when I start the vehicle…
Omaha, NE, USA
Can anyone tell me how to keep the a/c from turning on when I start the vehicle? I turn it off every time so I know it isn’t my “use last settings” in the climate menu. First world problems I know... just annoying that I can’t figure out how to turn it off.
auto climate is off
Temp set to 71 degrees
Rear climate is turned off
-REDRUM-
Omaha, NE, USA
Anyone? Bueller… Bueller… Bueller
Illinois, USA
I'd imagine most people are thinking you tried everything so no reason to respond. I thought there is one more setting for climate adjusting to ambient temperature. A/C when it's hot outside, Heat when it's cold, etc. I know I have it on for me anyways so have to imagine its same for your '20. Pretty sure it's a diff setting from 'last set' cause I always let car run for a couple minutes and great to have it cooled down or heated up respectfully.
Illinois
I have a setting in the auto start menu on my 25 that I use to control this..... I am not sure how that correlates to the 20-24 models though. I did just google it and found this though:
  • Use your vehicle's SYNC screen to access the settings.
  • Navigate to Vehicle Settings.
  • Select Remote Start Setup.
  • Choose Climate Control.
-REDRUM-
Omaha, NE, USA
Thanks, I will keep digging through the menus.
