Differential Brace & Warranty
Marietta, GA
2025 Ford Explorer ST 4WD
I like the thought of the differential brace yet am concerned about warranty. I have 38k remaining on the warranty. I am thinking of postponing this upgrade until after the warranty period (APR 2028 or 42k miles). Thoughts!
I'd probably do the same. I don't see anyone on the forum posting that the revised diff mount had failed.
The point of a diff. brace on the affected Explorers is to prevent failure in the first place. If you are worried, you could either get permission from your dealer or remove it if something happens since they are easy bolt-on items. I put mine on my 25' within a day or two of buying the vehicle. I will deal with the dealer if / when an issue occurs but I am doing my better part by trying to prevent an issue all together during, or after, the warranty expires.
Furthermore, if you want to get down and dirty, Ford would need to prove, not just "say" the brace caused the failure in the first place before denying a warranty claim.
To each is their own but the failures related to the newer single bolt set-up became a huge issue and resulted in a recall. The original 2-bolt design did not. Ford's fix to the issue and sticking to the single bolt set-up is laughable.
It couldn’t void warranty because it won’t cause any problems and it’d hard for them to say it caused the problem. Here’s two articles I did that explains that:
https://explorerst.wordpress.com/2025/04/17/lets-talk-differential-braces-and-why-they-are-needed/
https://explorerst.wordpress.com/2025/04/12/will-modding-void-warranty/
The reason why people haven’t had bolt snapping problems on these cars yet is either because:
1) People know the problem and immediately put on a differential brace
2) The people that run these cars hard didn’t upgrade because of no tuning
3) Ford new updated tune which pulls power from a launch works
R
Marietta, GA
Thank for the responses. I will look at the ID-Speed brace sooner. I will install prior to towing, probably this summer.
I don’t launch the vehicle most of the time. I do like the capable acceleration.
R
Marietta, GA
Team:
As evidence I followed advice on this topic, I have photos. The first shows the differential brace. The second is the modification I had to make - there was no manner to insert an original or replacement bolt in the top section... I used a socket-head cap screw and modified an Allen wrench to tighten.
The last is my grey steeda anti-sway bar. Since I am not charged by the photo, I added that too.
Thanks for the advice.
That’s happen if the diff is cocked from backing up and parking. Pulling forward rotates it up then there’s room.
R
Marietta, GA
I did not know that. Considering I backed up on ramps - it makes sense. Now I may have another project - I fought with this for a bit thinking I was doing something wrong but could not will the bolt into the space. Now I understand I need to create space... Thanks for this.
