Starting Issue
Atlanta, GA, USA
Having an issue that I can't nail down (yet). CEL came on, FordPass app reports a "issue with emissions" error. Used a scanner to pull the code....don't have the scanner in front of me and don't remember EXACTLY what it said, but something along the lines of a "small evap leak". I read online that it might be the fuel cap, so I did the whole "insert and remove the funnel several times". Issue did NOT go away. I used the scanner, reset the code....came back several days later.
Here's the thing. Occasionally, I'd say once out of every 20 or 30 cranks, it struggles to crank. By that I mean, press the button and it turns over for much longer than normal before it cranks. NOT an battery/electrical issue....it is turning over super fast...completely normal. It just takes longer to start. Once it starts, all is fine. You can turn it off immediately and start again it it will likely start 100% normal.
Hoping to get advice from the experts: Can this "evap" issue cause this problem? And if yes, what is the likely culprit? I've read that it could be the fuel cap, although I wouldn't think that would cause a slow start, maybe I'm wrong.
I've also read that it "could" be the evap valve under the hood. I found a great video to show how to replace but not sure if that can cause the slow start.
Any advice? I believe I have the "extended" warranty from Ford (going to verify) but not sure if it would cover this. My car is just under 60k miles.
Pyro_1284
Whittier Ca
Yes, sounds like your evap purge valve needs to be replaced. It’s a known issue, tricky install but definitely can do it on your own.
Southern New Jersey
It’s definitely the Evap purge valve. If you’re handy, I recommend doing it yourself. Don’t go to the dealership because the labor charge is insane. I was able to change mine out and under 45 minutes and the part is about $59.00.
It easy to remove and reinstall.
Here a video about it.
S
Atlanta, GA, USA
Sweet, sounds like I was on the right track. I found that video too...looks fairly easy.
Worth it at all to see if the dealer will do it under warranty? Not sure if it would be covered. I have the "extended" warranty, whatever that means (prob a waste of my money). Car will be just over 60k miles soon. Looks like I can buy it on RockAuto for ~$50. I've had good luck with them in the past.
My dealership is away takes 3 to 4 day to look at a car. I just order the part from Ford and replaced it at home.
