Code: P2C90 - Crankcase Ventilation System - Hose 'A' Disconnected on 2025 Explorer ST with Fen Fab V2 Intake
BigBenTX
Houston, TX
I'm curious if anyone has seen this code before? I have a 2025 Explorer ST with the Fen Fab V2 Intake, CVFab Intercooler with Hot/Cold Pipes installed as well as the Big Mouth intake.
I looked and don't see any loose connectors that are causing it or anything disconnected as the code says. Screenshot 2024-11-17 at 3.46.22 PM.jpeg
Ckeith42
Las Vegas
2025 explorer ST
I’m having the same code. Have you figured anything out?
B
BigBenTX
Houston, TX
Not yet, what modifications have you done? Seeing if we have any common mods. Are you a 2025?
Ckeith42
Las Vegas
2025 explorer ST
I have the Fen Fab V2 Intake, Fen Fab Hot/Cold Pipes, CVFab Intercooler and Thermal Exhaust.
Ckeith42
Las Vegas
2025 explorer ST
I have the Fen Fab V2 Intake, Fen Fab Hot/Cold Pipes, CVFab Intercooler and Thermal Exhaust. [/QUOTE
do you know if those things will void the warranty? Have you tried the dealer?
Canby, OR
I doubt you would have an issue with just those mods but it's always a risk modifying a car still under warranty.
B
BigBenTX
Houston, TX
I’ve got the same except for exhaust. I never got the code until I put the Fen Fav V2 Intake on. Then it pops it occasionally on a long extended pull from a stop to acceleration onto a freeway onramp
James902
Wichita ks
did anyone ever figure this out???
Plenty of 2025 cars with no issues and that CAI…same goes for 20-24 cars.
It’s been proven about 99% of the time it’s an installer error somewhere along the way. Rarely has it been a part issue. Double and triple check every aspect of your install…even if it “looks” good…get hands on and make sure it IS good.
Pewaukee, WI
@BigBenTX any resolution on this? I just got this recently and not sure what's up. I have similar mods, but they have been on the car for some time now. Just looking to see what you found if anything.
Cblack14
Alabama
I just installed the fenfab v2 and first test drive this code P2C90 came up. Any resolution?
NAiLs
Wisconsin
I installed my V2 a couple of weeks ago and also got this same code just now (I don't drive much)... Pretty annoyed to see people say it's an "installer error" and offer no suggestions other than the obvious that has already been done by everyone. Also, this isn't my first rodeo nor my first ST with an intake on it.
All of my connections look great and tight. The only one that I may have skipped on is the hose that goes from their silly 3D printed part to the intake pipe. I carefully slapped a zip tie on the 3D printed side, ensured it was tighter, but I'm afraid of this part breaking because it wasn't designed and printed well. I also am debating on shortening the hose that came with, because it feels a wee bit long and that may contribute to the issue. This 3D printed part is the only weird part of this intake, otherwise it's awesome.
I've got a little driving to do today and will see if the light turns off after the zip tie.
Edit 5/11/25
Drove 100-ish miles yesterday, with a few key cycles, and another 60 today. I ended up resetting the code yesterday after most of my driving and will observe if this thing comes back... but so far so good.
Cleveland, OH
2025 Explorer ST Vapor Blue
This code popped for me after 3k miles on the FFV2. Cleared it and came back 1,000mi later. I reassured it’s all well, if the computer thinks the PCV hose is disconnected, would that indicate too much vacuum because it’s not seeing any pressure in the crankcase?
Illinois
Agreed to everything you just said. I just threw the same code last night and came to the same conclusion about the crappy 3D printed T fitting. Look familiar?
Edit 5/11/25
NAiLs
Wisconsin
View attachment 29180 View attachment 29181
Yep - that's it! That piece is the only part of the intake that I'm unhappy with. I'd rather have seen these connections just go right to the pipes like factory, rather than using this silly part and adding yet another hose so the car can collect the data. I still have an AFE intake from my previous ST and that one was perfect with how all of the connections were made.
Illinois
One other thing I noticed about this connector that I have been thinking about. While cleaning some of the flash off it before connecting the hoses, I looked down the center if it to ensure there was no debris in there. It appeared to be necked down towards the center of the long side, the inner diameter of the tube was reduced and smaller in this section. I stuck a pick down there to make sure it was not another part of flash let over from a bad print job but it appeared solid like it was programmed to print that way. Did you look in yours by any chance and see the same thing?
I want to replace this fitting with something more OEM looking but do not know what these fittings are called. Any idea?
Cleveland, OH
I talked to Brett from FenFab. The 3D printed tee is for the evap system to bring the vapors back into the intake instead of atmosphere. Brett explained the P2C90 is due to the lower turbo intake hose up to the driver side valve cover. Check that the 90° barbed fitting is tight and the hose is snug.
Illinois
Interesting.... I will check that today. Was yours loose at all? I still think the hose that we zip tied (soon to be a worm clamp) on the t-fitting was good to do. It was actually pretty loose when it gets warmed up.
Cleveland, OH
Mine is feeding through a UPR Dual Valve Catch Can and we think the Clean Side of the can has something to do with reducing the vacuum. Going to pull the can out and run from the fitting direct to the valve cover and see if the code stays away.
Illinois
Oh, I am running a J&L mounted on the passenger side.
