Technically this was done a few weeks ago, but got my tune squared away with @GooseTuned. Just on 91 but it still rips! Power delivery is so much better and the transmission tuning is amazing. It's actually a joy to drive now in Normal mode with the transmission shifting through the gears smooth as glass. The tune is worth the price for that alone. I haven't tried the transbrake yet.
Then a few days ago I installed the CVFabrication hot side pipes and Turbosmart BOV. You can kind of see the black wrinkle pipes through this spaghetti mess of an engine. The install wasn't bad at all once you figure out the proper way to snake the old pipes out and new pipes in. Pro-tip #1: If you have bigger hands, I suggest getting your significant other with help with the passenger side turbo clamp. Not much space down there! Pro-tip #2: Reuse the factory connecter from the intercooler to the Y-pipe and just use the CVFab T-clamp on the Y-pipe side only. This makes the install much easier as you can side the connecter back up against the Y (the CVFab silicone connector is much harder to do this with), then once everything is located in the right spot push it forward onto the intercooler. Plus the CVFab T-clamp will not fit up under the radiator support on the intercooler connector.
New Mexico
View attachment 28828 View attachment 28829
AWESOME!!! Looks good man!
Looks good! I went with the FenFab hot/cold piping in raw. Definitely adds some cosmetic flare under the hood.
JADE97
2022 Ford F250 Tremor
Yesterday I did the 1st oil change and tire rotation @5000 miles. Today I need to set up the appointment to have a CV boot (or complete axle shaft) replaced under warranty. I will also have them do the sw update per the recall notice I got the other week. 1000002143.jpg
Installed the HSF skid plate. Was super easy and looks great! Only thing is, the plastic connectors wouldn't work with the added thickness. I have to get some a little bit longer.
texas
I didn't get pictures, but I had the RSA Stage 1 transmission installed. I'll give it a couple weeks before getting the Stage 5's & Nostrum goodies installed.
Marietta, GA
2025 Ford Explorer ST 4WD
I'll post pictures later:
J&L Air Oil Separator
Steeda Shock Tower Brace
Console Storage Shelf
Ford All Weather Floor Mats -- Three Rows
Ford Black Badges
Metal ST Brake & Gas Pedals
Splash Guards (F&R)
Gloss Black Wheels
Gloss Black Lug Nuts
To Do:
Steeda Anti-Sway Bar
ForScan Changes (FENG removal, etc.)
Ford Performance Tune? Need to be able to tow motorcycles.
Gave the family whips a quick wash with my new Ryobi electric pressure washer. Very happy with my purchase.
So between the Highlander and Explorer, which one has had more repairs and problems? Just curious.
