DoingOK
Smithfield, Virginia, USA
#41
Ceramic just can’t be beat. I had the front done the same as you then 50% on everything else plus the pano roof...made a HUGE difference down here in southeast Texas.
I'm sure Texas is murder during the heat. My buddy hooked me up for $100. Couldn't pass up that deal....plus he's ocd like myself.
It feels like someone supercharged the AC now. lol
DoingOK
#43
Picked up the Ford weather mats yesterday. They are not bad. I prefer the Husky all rubber mats I had in my Raptor but they weren't available.
DoingOK
#44
I only have 750 miles on the ST, so I may wait a few hundred miles......but, have this incoming. :cool:
CoastieN70
U.S. Coast Guard Veteran
Travelers Rest, SC, USA
#45
I have them in my ST and like them better than the Weather Tech's I have in previous vehicles... :)
Nothing lately but the parts list is gonna snap some necks...if everything ever shows up. lol
Toronto, ON, Canada
#47
I hear you unbroken.....
steeda sway bar
End links
Spd down pipes
Edge cts3
Cr performance stage 5 turbos
Waiting for install..... and sadly the first thing going on the truck is 275/45/21 continental snow tires on my factory wheels. O Canada!!!!
DoingOK
#48
Hmmmm.....let's see what this is all about. Where do you guys "mount" this normally in the Exploder?
Toronto, ON, Canada
#49
I stick mine in the little slot right in front of the cup holders in the Centre console hahaha it’s a perfect fit
CA
#50
Got the cheap 20" winter wheels with Blizzaks on just in time for the big snow storm tomorrow. OEM mudflaps went on at the same time as well.
Still have to set up the TPMS, but I'm gonna pick up a TPMS scan tool to make it easier.
I wasn't sure about the wheels originally, but they don't look too bad. $2600 CAD shipped for the whole set, mounted and balanced.
Sent from my SM-G960W using Tapatalk
DoingOK
#51
I just had my wheels installed with new tpms sensors........drove around for a bit and they synched up with the new units automatically. No tool used. Now I also had just flashed my ecu with a new ZFG Tune before driving but I don't think it is related.
DoingOK
#52
Also just loaded the ZFG Racing 93 tune this evening......OMG. Very impressed. :cool:
CA
#53
Hmm. I tried that, as that is how it worked for our previous vehicle. All that happened is that all the pressure readings went to -- . On my Transit van, it has to be put into learn mode, and then each sensor needs to be activated in a certain order with a scan tool, or by adjusting the pressure.
CA
#54
Nevermind. I must not have driven long enough originally. I just checked, and they appear to be sync'd.
iiwieft
Memphis, TN, USA
#55
Had SPD down pipes , Whipple cooler, and Borla exhaust installed. Using ZFG tuning. what a difference!!
TNSmokee
Collierville, TN, USA
Thread Starter #56
Wheel brand and specs?
DoingOK
#57
TNSmokee
Thread Starter #58
RTR Tech 5 wheels 20x9.5 +33 offset. Got them from: https://www.bbwheelsonline.com/rtr-...5x4-5-5x114-3-gloss-black-33mm-851GB-2096533/
Available in gloss black or charcoal. You'd want to run a 294x45x20 inch tire to get you close to stock overall height for speedometer consistency (0.96%). Hope this helps.
It does. Actually more than I asked for so I really appreciate it. Hers has the 20" tires already. Would they work temporarily work or would I need to replace the tires too?
DoingOK
#59
The minimum tire width recommended for a 9.5" wheel is 245. Your factory 255 will fit fine (may look slightly stretched compared to stock setup). See the pics attached for before and after specs with a new wheel setup. Clearances are all good and the wheel will only be 0.22" closer to the strut and the wheel will be sitting 0.78" closer to being flush (pushed out).
Good luck.
Rich
TNSmokee
Thread Starter #60
Good luck.
Rich
Once again, Thanks. I'm sold and if it was my daily driver then it would be no question. It's hers and she doesn't spend it quite like I do. The rim website is saved as a favorite and the tire of chose is the Continental ExtremeContact. Those tires are around 330.00 each so I may need to ride the originals for a little bit. I want the setup more flush and the spacers that UNBROKEN turned me onto are close but the wheels are going to put ME where I want to be, but again the ST is hers.
