2016-20 MUSTANG GT350R BRAKE CALIPER & BOLT KIT by Ford
PH03N1XSP
Dominican Republic
FORD EXPLORER ST 2021
Hello, I have a 2021 Ford Explorer ST and I want to put the GT350 calipers/brakes on it or some that you recommend, which is best? And where can I buy those brakes?
I have seen this
https://lmr.com/item/LRS-2120RK/shelby-gt350r-brake-caliper-kit-15-17
What I need to do the upgrade from my calipers to the BREMBO one
I have seen this
You can’t use that kit for the ST. The rear calipers won’t work and you need extra components for the fronts to work. You need to piece together it on your own. Here the full list (you will also need the caliper adapter brackets from Tony Hernandez on Facebook and if you have stock 21s you need a 3/4 IN or bigger spacer
Beedata
Miami
Thank you for the parts list.
Hull, GA, USA
I have the brembo set up on my 21 and I would recommend using different pads unless you like cleaning your wheels daily. They put off a ton of dust. I would also recommend looking at the superforged kit. For a little more you can get a full big brake kit.
Massachusetts
2023 ST
Are there any big brake options that will clear the stock 21" wheels without needing spacers?
Here my parts list.
Never did the swap.
Part #
FR3Z-1125-E RH-Front Rotor
FR3Z-1125-F LH-Front Rotor
FR3V-2010-BE LOADED CALIPER, FRONT RIGHT
FR3Z-2B120-G
FR3V-2011-BE LOADED CALIPER, FRONT LEFT
FR3Z-2B121-F
FR3Z-2001-L Brake Pads Front
FR3Z-2068-D Caliper Retainer Kit
W712276-S430 Bolt Banjo (x2)
W711784-S300 Brake Hose Washer (x4)
W717394-S439 Caliper Bolt (x4)
GT350 Adapter Brackets - DM Tony Hernandez
2019 Ford Mustang Shelby GT350, Shelby GT350R 5.2L V8 - Gas
https://www.opmustang.com/store/p344/2015-2019_Mustang_GT350_Brake_Hardware_Kit_-_Front.html#/
