25 Agate Black Metallic
St. Louis
Off the top of my head, I believe Ford removed the BOVs in 21 or 22.
SoCal
Following this thread.....just got me an Agate 25. Excellent work man! IMG_3463.jpg
L
Ldstang50
FL
Thread Starter #23
FenFab black billet emblems. Soooooo much better looking
L
Ldstang50
FL
Thread Starter #24
Engine bay pics. Pardon the dust
To work with the aFe intake, Brett made his hotside piping cross OVER the intake manifold. The stock piping runs in-front of the motor and under the intake.
This threw me for a massive loop (ontop of the BOV) as I couldn’t figure out how to route the new pipes. The y-pipe is essentially flipped in directional travel. It wasn’t until I went to his website and looked more carefully at his installed pics that I figured out the new routes
He did a phenomenal job running it right behind the strutbar. It doesn’t touch anything. The aFe driver’s side intake and cold side pipe come awfully close to touching.
Ran the car pretty hard on my way to Tampa today. All highway pulls 50-90 or so. No boost leaks, no CEL.
BBK on order. Gotta fill up the bigger wheels and more brake exposure
L
Ldstang50
FL
Thread Starter #25
A quick note, silicone couplers can be notoriously difficult to slide over metal piping. I initially sprayed WD40 to get them to fit, but then I thought back to my Evo days, use hairspray. It’s initially slippery allowing the coupler to slide into place, but then gets sticky ensuring a sealed fit.
L
Ldstang50
FL
Thread Starter #26
Side-by-side comparison of my car to a stock Explorer, mainly the ride height. You forget how tall these are stock after you lower them. This was a nice visual reminder of the massive, positive change
L
Ldstang50
FL
Thread Starter #27
This is a reminder to everyone to get their car aligned ASAP after installing lower springs. I dropped the subframe, but on reinstall, you can see how the thrust angle and rear toe were way off. This has practically destroyed my rear tires.
This is after about 500mi
See below pics. The thrust angle and toe had the rear dragging across the ground. The car was barely controllable changing lanes.
i don’t have the camber I want, so I’m considering camber bolts or even control arms
Illinois
View attachment 28238 View attachment 28239 View attachment 28240
How about the Oil fill? Is there room, it looks really tight from these pics.
L
Ldstang50
FL
Thread Starter #29
Just have to work around the strut bar, but that's easy to remove
L
Ldstang50
FL
Thread Starter #30
Superforged BBK done! If they come out with bigger rotors, I might purchase them. Even the 400mm doesn't fill-up the wheels
L
Ldstang50
FL
Thread Starter #31
I never planned on doing a strut bar. I’ll never push the car hard enough to warrant a better piece.
However…after doing the intake and intercooler tubing, the stock strut bar didb’t have the visual appeal. So off went the old, and on with the Steeda brace
L
Ldstang50
FL
Thread Starter #32
Almoalst ran over this kitten. I like to think my mods helped me avoid her… that and my absolutely stellar driving skills.
We adopted her. Not a mod to my car, just to my family IMG_7107.jpeg IMG_9185.jpeg
L
Ldstang50
FL
Thread Starter #33
Despite reinstalling the stock exhaust, but with a Gibson muffler, the wife says it is still too loud.
I ordered some Siless 2mm sound barrier from Amazon. A neighbor put it in his Foxbody and it made a huge difference
I hope this works. I do NOT want to reinstall the hideous stock exhaust
I’ll head to a friend’s shop in Tampa in a couple of weeks to pull the interior and install it. He owns a wrap shop and has guys who solely pull interiors
Illinois
Did you install the Gibson axle back or a random Gibson muffler? I went the Gibson axle back route thinking I didn't want the wife and kids complaining.... Can you believe she had the nerve to say it was NOT loud enough?! I can barely hear it inside the cabin. I should have gone the Thermal route!
Combatvet
Looking forward to all you have to share.
L
Ldstang50
FL
Thread Starter #37
I did the axle back. I kept the stock mufflers just in-case. I’m praying the sound deadening is the answer
Illinois
What part of the sound is the problem? I barely hear it. Most of the time I think the FENG sound is what I am hearing and not the exhaust. I know it definitely is heard on cold startup out side the car but that quiets down rather quickly.
What part of FL are you near? I am coming down in June.
L
Ldstang50
FL
Thread Starter #39
She says it’s loud. Our definition of loud is clearly different. That being said, the Gibson is about 7dBa quieter than the Thermal at 60mph. Logged both on my phone’s dBa meter.
Is it 100% accurate? That I can’t sayut it’s the same equipment used for both tests
The noise above 80mph is mosty wind, so peak sound is likely that, not the exhaust
I did a screen record, but I can’t post the vids
I’m in Palm Beach
