Cold air intakes 25 ST
Mrsig226
Massachusetts
Hey All, apologies in advance If this is posted somewhere, I looked and couldn’t find it probably use error on my part…. interested in getting people‘s opinions on cold air intake…just picked up my 25 ST last month and want to put a cold air intake on it not sure people’s opinions K&N AFE etc. which one you folks going with thanks in advance
CAI do nothing for power, especially since you can’t tune the 2025s. A CAI would just be for looks. Sound wise the only that does that is the Fenfab intake, it adds a lot of fun turbo noises.
Charlotte
Just to add, when there is a tune available for the 2025 check with the tuner whether or not there are gains to be had with the intake. With my setup, ZFG told me that only in "race" mode which is now my "sport mode" in the drive selector would benefit from a CAI.
Intakes won’t do anything unless you’re pushing the car to its limits.
I only push things to "the extreme" personally. ;)
Well then the 25s probably aren’t the best choice because they’re not going to be tunable for a long time, if ever.
Charlotte
Fortunately i have a 24', I think you are thinking the OP. :)
On another note, really think the 25 has a chance at being un-crackable?
Yep my mistake. I do think it’s going to be a very long time at the very least, but has a high possibility of not being cracked ever.
As I understand it the Mustang and F150 stuff that can’t be cracked yet…the 25 ST is a generation newer than even those.
Chicago
Ford Explorer ST
Wouldn't surprise me if they wanted to make sure the warranties expire before letting people tune these after all the diff bolt failures they had to replace. Saving pennies ended up costing them a lot dollars.
Could be. I think it’s also that they might want to corner the aftermarket game themselves. If Ford Performance comes out with a tune, 2025+ owners will only have one choice.
Illinois
At this point, I would have no problem with the Ford Perf tune for my 25! Fingers crossed....
Cblack14
Alabama
Thankfully this comment didn't age well!
Yep thankfully! Thanks to someone at Ford who leaked some info.
BitViper
WeNoGottaRancho
Already received my tuner and am waiting for my base tune.
You are correct sir... are there any significant returns on getting one and leaving most of the stock parts alone...
Perq
Virginia
25 Explorer ST
I have an exhaust, lower springs, and diff brace with ZFG Performance tune and it’s a night and day difference on power. Would definitely benefit from an intercooler which will be my next purchase.
Charlotte
You 10000% will. The engine wont start pulling power after what seems like the first 100ft of WOT. IC upgrade will allow her to keep on pulling with full potential power available without a heatsoaked IC getting in the way. The stock IC is laughable.
I'd say the IC upgrade is arguably the first upgrade any ST owner who is looking for more performance, even helps with stock everything else.
Combatvet
enphor is correct. I went about it the wrong way, I went exhaust, downpipes. I should have went intercooler first.
But to stay on topic, I did order a FENFAB V2 as my intake because I dig the hand fabrication aspect.
USN_Ret.
Tucson
Could y'all put some links for these products?
My Google-Fu is weak lately!
