Greetings everyone,
There are significantly more choices available for 20 in. rims that would vastly improve the skidpad performance of the ST (i.e. Toyo R888R, Nitto NT01, Falken Azenis RT660 only go up to 20 in.). A few sizes of the aforementioned tires are on the borderline of the load rating, however, they are not too far off from the OEM tires on the Cayenne Turbo GT which are as follows:
Front Tires (rim size 22 x 10.5") Pirelli P Zero Corsa
When looking at the weight distribution of the GT, it is 55% front-loaded and the front tires are rated at 2,094 pounds each. Under maximum braking, the front tires will be loaded at about 72.6% (3,664.5 lbs for the Turbo GT front wheels) according to ChatGPT. The number for the ST is slightly less at 68.9% front-load shift, making the total "front tire load" 3,238 lbs.
There is likely some suspension wizardry affecting this number, such as the active anti-roll bars in the Turbo GT mitigating load on outer wheels during "at-the-limit" cornering, but it shouldn't be too far off.
If Porsche is leaving an allowance of 523 pounds in the GT, it would be reasonable to assume that the minimum load rating for a tire on a track-focused Explorer ST would be 1,880 lbs.
Now, if 20 inch tires are inherently disadvantaged to 22 inch tires for track performance, all of these are moot points and we might as well apply the same wheels and tires from the Turbo GT or RSQ8 to the Explorer ST and call it a day. Based off all the research, it is tough to determine whether Porsche and Audi put 22 inch rims on the SUV's they sent to the Nurburgring specifically to break records, or to break records in "production guise." It wouldn't be a stretch to assume that very few people would opt for 20 inch rims (if they were offered) for aesthetic reasons.
What tire and rim combo would theoretically provide the best value for handling, with emphasis on cornering ability?
The use case scenario is 1-2 passengers max, weekend usage, dry to damp conditions, 50-100 F temps, and 100-200 pound weight reduction (prioritizing unsprung weight). Since there are limited options for 21 inch tires, it'd be ideal to focus on 20 inch tires vs 22 in. imho.
What are your thoughts?
Once the built engines from ZFG are up and running, it seems likely that we can achieve something worthy of comparison, or dare I say even more capable, for a fraction of the price.
- Size: 285/35ZR22
 - Load Index: 106
 - Max Load: 2,094 lbs per tire
- Size: 315/30ZR22
 - Load Index: 107
 - Max Load: 2,149 lbs per tire
. The suspension and steering components look like toys compared to a vehicle designed for those conditions.
