Sync 4 13.2"
Dpratt202
Los Angeles, CA, USA
Ford Pass work directly after the swap. If you want to remove your phone and re-add it you have to install the Sync 3 back in.
Here a video with the new APIM with navigation.
Nice! Well, I'm hopeful and want to get everything working. Is that running Sync 4 or 4A?
Stone17
Thread Starter #82
Sync 4.
Dominican Republic
Ford Explorer ST 2021
#83
3D printer cover and work is done :cool: this look amazing
KoolAl44
Alabama
#84
So you would have to remove ford pass from sync 3 before pairing it with the sync 4 is that what your saying
Stone17
Thread Starter #85
Only if you remove the vehicle from your Ford Pass and want to add it back.
KoolAl44
Alabama
#86
Thanks
Sent from my SM-F926U using Tapatalk
KoolAl44
Alabama
#87
Another question are you able to get Hotspot throught the sync 4
Stone17
Thread Starter #88
The ATT Hotstop. I never used it before.
California
#89
I have a 2025 ST and I have the AT&T hotspot. I pay like $20 a month for unlimited. Unlimited is a bit over kill I think but when everyone is in the car its nice to not have to worry since my kids and their tablets use a lot of data. You could probably get by with less than unlimited.
KoolAl44
Alabama
#90
I have hotspot currently but im upgrading to sync 4 and was making sure it still existed
KoolAl44
Alabama
#91
Nope no 360, reverse braking or in car wifi
after being able to have time to look through things I was able to get it to speak with the sync4 APIM.
Still having issues with SiriusXM, sometimes it works, most off the time it just says loading.
Navigation both native and through CarPlay gets lost, noticed the compass also doesn’t work accurately, (will say south when heading north, east instead of south). With that “intelligent” cruise control is intermittent but will work once or twice randomly.
can’t pull up rear-climate controls and before the swap I had the rear controls locked out to prevent the little from messing with them and now I can’t change it.
Visually, when changing temp or volume the circle pops up but doesn’t show any changes or current values.
The APIM seems to have listed any and all options that could be made in any vehicle which is so helpful…. it’s also pulling an error saying communication fault with the telematic unit to be expected.
What did you do to get it to speak to the apim
KoolAl44
Alabama
#92
I got everything working but the camera.
Shaunishere
EMT
Vermont
I had to remove two pins from the harness I was sent from the fordsync4 people. Everything works fine when I update the as built lines. But after turning the vehicle off and returning later Siruis deicdes to just not work only shows "Sirius loading" also any visual changes such as using the unreal engine theme reverses back to the traditional sync4 visual. But other changes such as HVAC repeaters, reverse camera settings, cruise control settings etc are retained by the APIM.
I'm at a complete lost for the issues I'm facing. Fordpass works properly since removing the pins and doesn't give me an issues.
I've been toying with the idea of putting this APIM in my 21 f150 and see what doesn't work but it's still winter in VT so I haven't been in a rush.
KoolAl44
Alabama
#94
So i finally done with everything. Everything works finally got the 360 camera to work. Ford pass works, on screen climate control work, massage seats driver and passenger. Only other issue was Siruis does exactly what yours is doing and no audio on AA or CP. But im going throught some more ab
KoolAl44
Alabama
#95
Inbox me on fb. I can help you out with those issues. I finally have everything working now. My facebook name is KoolAl
Stone17
Thread Starter #96
I had the same issues with the Sirius XM. You need to change the sat radio type. If you know what As-built line items its under, I can check what # my unit is.
KoolAl44
Alabama
#97
I sent him my AB. My Sirius XM radio is working.
2020 Ford Explorer St
#98
I think I am going to wait for infotainment to release something for the Explorer. It looks good tho. Congrats
#99
It wouldn’t be any different then tho most likely, and really overpriced.
Stone17
Thread Starter #100
I wish they would get a kit going. No update yet.
