Eibachs Installed on my ‘25
Moorestown, NJ
Hey Y’all
Got some time to install the Eibach springs on my ST. Install was a breeze thanks for HSF install video!
RusW1
Missouri
looks really good. Do you like the stance? Does it sit level or maintain a slight forward rake?
Gainesville GA
25 Explorer Active
Looks really nice! How’s the ride quality so far? I’m about to lower my Explorer too, but I’m stuck between Eibach vs H&R springs.
Hey Y’all
Eibachs will sit very close to level, and lower the car the most compared to other lowering springs.
From what I’ve heard, Eibachs ride the best.
Charlotte
I have the set sitting in my garage to get installed, can't wait!
Coloradostan
It has been my experience with eibachs that they have a butter smooth ride, but in no way floaty and in every case help a lot with squat and dive. Iv'e installed 4 sets on 3 diff brands and all seem to settle more than expected, to be clear that isn't a bad thing in most cases.
Is that the case here? did you get what you thought or after a month do you find its lower than truly expected? Also what are the wheel measurements and tire size? Pls and thx.
eidt - Also, about alignment, specifically camber, can you drop a 2025 on eibachs and still have enough oem adjustment to keep it within oem spec? or are other suspension components needed (eg, high offset balljoints and the like)
Any competent alignment shop should be able to bring alignment to OE specs with the Eibachs.
Illinois, USA
Have to replace the struts and been wavering on which springs to go with since i'll be in there. You may have sold me...though I was moving towards the E's. Had a couple sets in the past that I was always happy with. Nice color too!
Coloradostan
Good to know.
Just to be clear, this is my first vehicle of this type, as well as my first Ford. Every previous eibach install has been on sport sedans or hot hatches (VW, Honda, Scoob), so there is a fairly low tolerance before reasonable tire saving, alignment adherent type actions are best implemented. I'm still learning what is "excessive" for this platform. If you know about eibach, you know about the raceline springs, the red ones. On a 2001 Prelude, prokit? (black springs) great! Raceline? (red springs) . . . . . naw dawg, I'll take my car . . . .
I realize at this point my comments are best moved to a suspension subforum, but I am still interested in the whell measurements, most specifically offset, rim size and width, and tire size choice. Bran, it looks good, let us know.
Good to know.
Yikes that reply is all over the place. What are you talking about?
With you on that one, was still lost after reading it 3 times.
Coloradostan
Yikes, engrish not your first ranguage? k...
"Just to be clear, this is my first vehicle of this type, as well as my first Ford. Every previous eibach install has been on sport sedans or hot hatches (VW, Honda, Scoob),"
-What type of vehicle is this? An suv. Volkswagens, Hondas, and Subarus that traditionally get modified are typically small sporty 2 or 4 door vehicles. Pretty straightforward man. One is an SUV the other is Prelude... one of these is not like the other....
"so there is a fairly low tolerance before reasonable tire saving, alignment adherent type actions are best implemented."
-If you don't want to scrub an expensive set of tires, additional alignment products are needed, like high offset ball joints or camber plates. You could of just asked, but you weren't gonna do that were ya?
"I'm still learning what is "excessive" for this platform. If you know about eibach, you know about the raceline springs, the red ones. On a 2001 Prelude, prokit? (black springs) great! Raceline? (red springs) . . . . . naw dawg, I'll take my car . . . ."
-excessive /ĭk-sĕs′ĭv/ - Exceeding a normal, usual, reasonable, or proper limit. As I already stated, this is my first Ford and first SUV, as such, I am not yet familiar with what constitutes excessive when dropping an Explorer. Thus, I provided a real world example of what any real car guy would recognize as excessive, ie, the ride quality of Racelines is shit and should only be used on the track. Additionally, keeping the car even vaguely in oe measurements is costly, inconvenient and for the average user, excessive.
"I am still interested in the whell[sic] measurements, most specifically offset, rim size and width, and tire size choice."
-Really, a single misspelling threw you off that hard? I wanted to know what the offset, rim size and width, and tire size are... pretty clear.
"Bran, it looks good, let us know."
-Bran is the OP, I'm letting him know it looks good and to let us know on the specific measurements.
It never fails, the douchebags can't help themselves. There wasn't anything weird or unusual about that post, but you went out of your way to be dick to the new guy instead of just asking what I meant. Good lord man, way to hijack the thread and disrespect the OP. and BTW, it's not my fault that your reading comprehension is at 3rd grade level.
jesus tap dancing christ, at least I now know who NOT to listen to for good info.
Drunk post much? Ramble on!
Combatvet
Well, this was going to be my first mod but after getting multiple estimates of $1200.00 for the springs, installation, and alignment I think I'm going to go with the Thermal R&D exhaust first.
Nightshade
Firefighter
Alberta, Canada
Hey Y’all
I see @Bran1093 was last active last month, can someone who has these wheels (Giovanna Haleb), know the size and offset on this one?
I think it's 22x10.5, 5x114.3, +40 mm offset but I could be wrong?
+40 offset is way to inset and would rub the strut.
Nightshade
Firefighter
Alberta, Canada
Interesting, I reached out to Giovanna, seems like these Giovanna Haleb (Big Cap) style wheel of theirs only comes in +40 offset for 22x10.5. Unless the ones the OP has is in 20s? If yes, then would be 20x10.5 +30 for sure.
