Conti ExtremeContact DWS06 Plus 275/45 R21
Drsobczakst
Chicago
OKay, so i have read all the threads i think i can about tires for the ST. I love the Conti ExtremeContact DWS06 Plus tire that i have run on other vehicles in the past however, but never could find it in a 275/45 R21.... well, I happen to go on the Conti's website and wouldn't you know it, THEY MAKE IT! However, all the local shops i have im my area seem to think is not a real thing or not an option for them to get it.... Wanted to see if anyone here has also seen this as an option and if so, where and could people get them from Conti or not. Thanks!
Go up to the 295/40…get more tire on the ground and it fits fine. If you go to Discount Tire they have their “house” version of that same tire called the Control Contact Sport SRS+ which runs cheaper than the DWS06.
This is the way to go. The 275s are way to narrow these cars.
D
Drsobczakst
Chicago
Thank you, I do not run spacers. Would i need to if i move up to a 295/40?
Electionz
New York
ok perfect. I feel like I keep seeing all these posts of people saying you need to change it in Forscan when you change to a different tire size. The speedo will be off etc etc
Well Speedo will be off by a little but it isn’t a big deal. If you want it to be exact you change it in Forscan.
Rick4345
Illinois
2024 Ford Explorer St-Line
You can get them through Tire Rack. If you feel real ambitious, you can go to Tire Rack in South Bend, IN and have them installed there. If you're into cars at all, it's like being a kid in a candy shop!!
Massachusetts
2023 ST
Weird, I had no problem calling up and getting quotes on those tires. I put a set on my car last week in the 275/45/21 size. Great tire. Rides nice.
Wish i knew about the 295/40/21 option however. Those tires are $375 each in 295/40/21 vs $400 each for 275/45/21. Oh well...next time.
D
Drsobczakst
Chicago
of the DWS06 or the discount tire vrsn?
D
Drsobczakst
Chicago
Interesting! well good to know :) i have run them on almost everything i drive but my current tires are a 7/32 and 8/32 so i have time still before i need a new set!
Massachusetts
2023 ST
I’ve run a few sets of these on other cars. This is prob the 6th or 7th set I’ve purchased but first on the Explorer.
so far I’m happy. I’m not racing my ST, but for my spirited drives they do quite well.
downside was $399/tire in the stock 275/45/21 size and apparently $375/tire in 295/40/21
And only $356 each for the Control Contact Sport SRS+ in a 295/40 that’s every bit as good as the DWS06.
