Resources on Ford Approved Engine Oil for the 3L EB
BeyondEOD
Active Duty U.S. Air Force
Missouri
Per ford you should be using an oil that meets or exceeds the WSS-M2C961-A1 standard.
Ford Chemical and Lubricants info page:
https://www.fcsdchemicalsandlubricants.com/resources/quickreferencecharts
Great post here on the Bronco forum with everything meeting the specs of Ford for 5w30 offerings: https://www.bronco6g.com/forum/thre...ist-that-meets-ford-spec-wss-m2c961-a1.82783/
Direct Link to Sheet: https://docs.google.com/spreadsheets/d/1qsjmpZR7Y1Qb6u_3PBp0WcCeuuihcL4_3vpz6gwNBTM/edit
What makes the WSS-M2C961-A1 standard:
- Viscosity: SAE 5W-30
- ILSAC Standard: GF-6A
- API Certification: API SP
- Engine Tests: The oil must perform well under several ASTM tests, including:
- D6557 (Ball Rust Test)
- D8111 (Sequence IIIH - for oxidation and viscosity increase)
- D8350 (Sequence IVB - for valve train wear)
- D8256 (Sequence VH - for fuel efficiency)
- D8114 (Sequence VIE - for LSPI control)
- D6709 (Sequence VIII - for high-temperature deposit formation)
- D6335 (TEOST 33C - for deposit formation under thermal stress)
- Additional Requirements:
- Oils need to pass a Ford-specific chain wear test, which indicates durability for engine timing chains.
- They require a Total Base Number (TBN) greater than 10, which is higher than some other standards like ACEA A5/B5 which require a TBN >8, indicating good acid neutralization capability.
- Ford also prescribes additional oxidation tests to ensure oils do not degrade too quickly, enhancing engine longevity.
- Compatibility: This spec supersedes the older WSS-M2C946-B1 standard. Oils meeting WSS-M2C961-A1 are generally considered backward compatible for engines specifying the older standard, but for warranty and optimal performance, Ford recommends using oils that meet this newer specification.
- Market Availability: Brands like Motorcraft, Valvoline, Mobil 1, Castrol, and Pennzoil have oils that meet this specification. However, not all oils from these brands that meet API SP or ILSAC GF-6A will necessarily meet WSS-M2C961-A1 due to the additional Ford-specific tests and requirements.
**The information above is derived from various sources discussing Ford oil specifications, particularly from forums like BobIsTheOilGuy and Ford-specific forums.**
Good info, thanks. So far been running Mobil 1 Full synthetic when the oil life is around 10%
B
BeyondEOD
Missouri
To be honest, Havoline that is not a name you see thrown around often. That stuff looks good on paper.
MIdwest
And it's $4.67 per quart when you get the 2 box case.
Yeah I’m gonna try two boxes just for it’s and giggles
Charlotte
Hah I had it in my Walmart cart yesterday and went to purchase this morning, Out of Stock. I guess everyone here ran and ordered it up!
Nando
2021 FORD EXPLORER ST
Is this one attached here on pictures a good oil for thi ecoboost engines?:rolleyes:
Charlotte
I would look for SP grade as it is the latest spec designed to prevent LSPI
