2025 ST test mules for forascn changes
#81
After software updates were applied, it seemed better for a little while. But, pretty quickly it was back to the same inconsistency of walk-away lock, and a real desensitization of the handle touch locking.
I reverted the changes in Forscan, and the handle locking immediately feels better. Weird.
Fozzy86
Zelienople PA
25 Explorer ST
#82
Good Morning.
I think I found a solution for the FENG
I have a 2025 with the 14 speaker audio.
my as built for the APIM 7D0-09-05 0055 0060 20BA
changed to 0015 0060 207A
change the 3rd digit to a 1 and no more FENG :)
Thanks!
TXST29
2025 ST-Line
#83
Ok, checked and have the latest version. This is the error I'm receiving with regards to the tune. View attachment 27222
Well, I haven't seen any updates on forscan and no responses on estimated timeline from them. Anyone have workaround for this?
ANawaz
Canada
#84
So curious if this is a feature we could turn on. It’s more for the new 2025 Navigator with split tailgate so it’s “hands free” since there is no more kick to open. There’s a line in the APIM 7D0-09-03 that looks like it would add the option within the screen. But couldn’t find anything under the BCM that would need to be coded if needed to.
This feature was also added to the job-2 25 Explorer Platinum trim. It'll be great if we can enable it on Job 1 STs.
Sent from my SM-S918W using Tapatalk
DavidR3906
2025 Explorer ST Line
#85
I played around a bit but couldn’t get it. I couldn’t get the automatic option to show up on the screen. I got the hands-free option to appear, but it wouldn’t show automatic (open on approach) slider. I need someone smarter than me lol.
Thread Starter #86
The programing in the module most likely will need updated with job 2
Ota may resolve that in time
I don't have access to that info but will inquire.
Would be a nice feature to turn on
DavidR3906
#87
Also interesting find. That screenshot is from Ford Canadian. Which open on approach is available now. But if you go to regular Ford site for US it’s not an option or Platinum’s. Looks like Ford is only making it a factory option for Canada.
California
Good Morning.
Thanks!
I did not try the As Built format but i think i found how to disable it with the simple enable/disable functions. I have a 25 ST with a build date of 9/24 and every option possible.
In forscan under the APIM module, scroll down to Propulsion Sound Setting. Disable that. I’m 90% sure mine is quieter in the cab. All modes sound the same now where sport mode was noticeably louder before.
NAiLs
Wisconsin
I've got a 12/24 built 2025 and have verified that I can disable FENG and enable Bambi mode. I wasn't able to get the approach lighting to work for some reason... I must have missed something or it was wrong. Would be a cool feature to have, considering my wife's Lincoln Corsair has it.
Flipp_96
Chicagoland
This worked for me.
NAiLs
Wisconsin
digitaltrucker
2025 Explorer Platinum
#92
Sorry for jumping in here with something different. Can some one tell me if Forscan can (Program) add the "b pillar" illuminated keyless entry on a 25 Platinum? If yes what are the changes?
Thanks
#93
Just to add my experience:
I tried enabling the approach lighting and found a big reduction in touch-door-handle-to-lock sensitivity. This was very similar to what happened after enabling walk-away-lock. Reverting the changes brought the sensitivity right back. Not worth it for me to have to keep turning around to lock it after it doesn't respond.
DaveK
NY
Thanks
I was not successful enabling the keypad via forscan, I had to take it to the dealer to have them enable via FDRS,
Nightshade
Firefighter
Alberta, Canada
#95
Circling back to this as I've had a few people ask me on this. Has anyone else had touch door desensitize after doing the "approach lighting" change? I know 21+ F-150s have it as standard, don't see why it would cause issues to the 25 ST touch door handle sensitivity? It seems like only a few people have this issue where many reported they didn't have any issues.
nynd
Canada
#96
When I revised the powerpoint timeout from 4500 to 500 sec, looks like it goes off immediately when the door is open. Any thoughts? I would have thought it would have stayed on for 8 min or so after you exit.
Marietta, GA
2025 Ford Explorer ST 4WD
#97
I got the global window close (for front windows) to work. It works by double pressing the lock button on the fob and holding on the second press. This process did not work per the factory settings as only global open worked when enabled in the settings>Vehicle>Windows.
Here are the forscan changes I did for it to work
Changed the below options in BdyCM from Disabled to Enabled
Global Close - Initial Value
Global Close - Personal 1
Global Close - Personal 2
Global Close - Personal 3
Global Close - Personal 4
Global Close
And changed one value each in DDM and PDM as below View attachment 27110 View attachment 27108
Global Window Close works as described by Anawaz:
BCM 726 11 02 x1xx x1xx xx--
BCM 726 22 01 x1x1 x1x1 x1--
BCM 726 27 02 x1xx xxxx xx--
APIM7D0 09 01 xxxx x?xx xx--
There is a list; to keep Temp Mobility Kit Disabled and retain Daytime Running Lamps Control Function: E
To enable Temp Mobility Kit: F
DDM 740 06 02 xxxx xxx1 xx--
PDM 741 06 02 xxxx xxx1 xx--
This is identical to ANawaz, but just gives the codes required. For my application, I had to change the APIM (7D0) module as well. This is working on an AUG 2024 Build '25 ST.
Marietta, GA
#98
Good Morning.
Thanks!
I have the same code in my "As Built" file for the APIM. I can follow your change in the first block of four (0055 to 0015). The last block of four, (20BA to 207A), is not noted in my google sheet. These last two digits are listed as "**--" then it goes to the next aPIM group (10). Do you have documentation on the last two elements? How did you find this? I am curious.
#99
Anybody made headway with FENG / propulsion sound?
I swear with it disabled in APIM, there is still some piping into the rear speakers.
