Police interceptor wheel pics
PMA
Rosseau, ON, Canada
Can anyone confirm if you actually needed different lug nuts or if the stock ones work with the police center caps?
The stock wheel nuts will not work with the centre caps. I had to purchase new ones.
locoliberty
michigan
Oh great now I have conflicting information on the forums. guess ill find out on thursday when mine get installed
locoliberty
michigan
265/60R18 Bridgestone DM-V2, since they were cheaper than other size options. 20221229_162459.jpg
H
Ho Chi Mane
Guest
No one has popped on this thread in awhile so thought I'd add some more info for folks who want to go this route.
My 18x8 PIU wheels arrive this week. $493 USD including shipping [from Canada to the US] which is $100 less than you'll pay for 1 wheel in the US. I got mine from https://www.rivercityfordparts.ca/
In terms of tire sizes for these wheels, 265/60/18 or 255/65/18 will not only work, our test drivers couldn't discern anything noticeably different between the two sizes when ran side by side on the road, dry, or wet track [running '22 ST's] so choose based on price and availability over what someone tells you is the "better" size.
The stock lugs will work and no spacers are required. I did grab a second set of of lugs, but that's just me and my penchant for preparedness.
As far as the width and the "empty look"...um...the OEM 21's wrapped in 275/45's aren't wide enough and have an ugly gap as-is, so potato/po-TA-to? 265/60/18's sit nearly an inch bigger in circumference than the 275/45/21's and the width difference is < 7 millimeters. When you see them in person the fuller height makes up for the slightly narrower stance, at least optically.
Ultimately, it's a preference thing, entirely subjective, and that's cool, everyone should be able to enjoy what they enjoy, simple as that. For me, I'm simply hard on my vehicles, I drive 50-60k mi/yr and range from highways to NFR's. So PIU wheels with some MI CC2's make the most sense for me and I can live with the look. Worst-case scenario, I get tired of it I'll go with some gloss black 20" Savini BM13's with 255/55 PS4's and keep the CC2's on the PIU's in the garage for a rainy day. I think that's my favorite thing about the ST, it's virsitiliy in function and in look. It can be an absolute sleek and stylish badass [look at all unbroken has done, it's killer!], they can be absolutew sleepers, or they can go unnoticed, totally blending in with the surrounding vehicles. I'm leaning towards mine blending in at the moment.
Rick4345
Illinois
2024 Ford Explorer St-Line
#27
Did you ever find out? If I remember right we had to have a different lug nut on our Fords. Our department was losing so many full size hubcaps that Ford did a one for one trade. The new lug nuts had a shoulder on them for the hub caps to fasten to.
locoliberty
michigan
There is a different PN for them listed, but ive been just fine using the lugnuts that came factory
KoolAl44
Alabama
#29
I know this is old but I used my stock lug nuts and the caps fit. Lowered on eibach and 1.25 front and 1.50 rear spacer
Mako
Canada
Hello good sir, what's your tire spec on those 18s?
PsyKoST
South Dakota
21 Explorer ST
#32
Stock lugs indeed work with the hub caps. I have them. View attachment 16079
What is your tire setup and are you lowered and are you running any spacers? I can live with this look for the winter!!
