Mirror tap for Radar detector
Wylie, TX
How exactly do you remove the cover behind the mirror to tap the power cables? Just yank it off? Making sure I don't break anything lol.
Lakewood, CO, USA
Yes, I just did this today, it just pulls off, I'll post pictures along with which wires to tap.
Lakewood, CO, USA
It's the harness on the passenger side, wire 1 (white) is positive and wire 3 (black) is ground.
Lakewood, CO, USA
It was much easier to pull out the mounting clip to see the connector straight on.
Lakewood, CO, USA
It came with zip ties to attach it to the existing mirror cable. I used a blendmount bracket attached to the mirror.
Zermus
Wylie, TX
Did you use the 15" mirrortap? My blendmount came with the 10" and it's a bit short and I have to have it come out the side of the cover lol.
Lakewood, CO, USA
I think it was 12"
Sent from my SM-N986U using Tapatalk
Los Angeles, CA, USA
so what you guys are doing is just finding an Ignition Hot wire to source power from ?
so i could use this method to wire in a Dash Cam?
Lakewood, CO, USA
Nope, power off the mirror.
Lakewood, CO, USA
I maybe read that wrong, yes its hot on ignition.
Commerce Charter Township, MI, USA
Does yours turn off in reverse? Mine does, and it is set up the same. I don't really worry about it since I don't need my detector or dash cam while backing up...
Lakewood, CO, USA
I don't think so, but I can check.
Lakewood, CO, USA
Mine doesn't turn off in reverse.
