Windshield inside sweating
lawman1290
PA
Hi All,
I have a 2022 ST my windshield when it has frost on it and I get in it start and turn on the defrosters and everything heats up and starts to melt the frost my windshield inside has sweat some times heavy on the inside to the point of starting to run down the windshield. I've never had this happen to any car I've owned and I'm 62 so this seems strange. Happen to anyone else. I don't want to seem like a fool going to the Ford dealer if this just happens.
Thanks
Bob
Hi All,
Thanks
Bob
No that’s not right. Does the airflow and temp feel the same on both sides? My guess is you are not getting full flow on that side.
Polizi212
Check your Floors for Moisture, That kind of frosting on the inside usually means you have excessive moisture inside the cabin! I suspect your passenger side will be damp or possibly the drivers side if you have a sunroof! I had water getting in because the Ford Tech didn't snap the plastic down all the way when they did some work and it leaked! this was on passenger side by the battery under the windshield! once it was back in place all the issues were gone!
