Why there is no tow eye .............
Skunk Hollow
Where would one screw it in ? ;)
Speak for yourself. My car has a front socket for it. But, yeah, definitely check before you go getting bent out of shape about it being missing.
M
Skunk Hollow
If your ST has it, you are one of the few. The majority I've seen with the cover removed do not have it. My ST is a late build. March of this year.
Los Angeles, CA, USA
ours was built for CA and dont remember seeing one.
i know Ford only put them on for select regions, from what ive read.
The midwest
From the earlier owner's manual (not even included in the latest revision):
M
Skunk Hollow
Yeah, key word .......... Countries! We are not included. Not a one of the several hundred PIU's I've seen at the N TX Skunk Works with the nose clips removed for light and push bumper installs has a threaded collar in the cross beam.
Will3
Midwest
Mine has it. Built September 2019.
M
Skunk Hollow
You are one of the lucky ones I guess. At some point, Ford made a running change. It is not on my ST nor, any of the PIU's.
