Whistle sound when pressing on the gas pedal
vallord
Lincoln, Ontario, Canada
2020 Explorer ST with 66,000km. It started to make what I would described as a whistle sound when pressing on the gas pedal at about 60km/h and above. The pedal doesn’t need to be pressed hard.
https://youtube.com/shorts/5tOdrVk_9Ig?si=RwilrZVj2ULPI2Pk
I’ll stop by the dealer tomorrow.
Anyone has any ideas what it could be?
Black 2020 ST
My guess is a vacuum leak.
vallord
vallord
Reports whistle type noise when pressing accelerator light throttle over 60kms/hr, will stop when letting off, test drive and report
• Tech Cause: Road test for concern> Noise from rear axle assy.
• Visual inspection> severe fluid leak from rear housing. suspect cracked housing
• Removed drain & fill plugs & found excessive metallic debris, indicating internal component failure.
• Requires replacement of rear axle assy.
• Tech Comments: Rear axle assy. & hardware ordered.
• Replaced rear axle assy.
• Road test after repair> O.K. - Warranty
Nice. Glad you got taken care of!
This may be happening to me at 52,000 miles! My rear axle/suspension feels bouncy and feel resistance and shaking from the back.
