Wallingford Conn area
Wallingford
2025 white ford explorer st
Hey All,
New to area and looking for some ford guys to do a few items.
Installing springs
Wheel spacers
Wrap
I Bleed Ford Blue
23 Rapid Red Explorer ST
Wheel spacers are easy, if you can change a tire, you can do wheel spacers. Just make sure you get hub centric spacers so the load is on the hub itself and not the lugs. The 20+ explorers use a 5 x 4.5" or 114.3 mm bolt pattern with 14mm wheel studs and a 70.5 mm hub bore. BTW all mustangs from 1994 to present use the same and the early explorers up to 2010 did too. The 11-19 explorers had a smaller 63.4mm hub because they were fwd based platform. The only difference is the mustangs used a 1/2-20 wheel stud up to 2014, and the explorers up to 2019.
