Vehicle Indicator Warning Lights
I had this light pop up this morning and can’t figure out why. I checked for DTC’s but there’s none. Checked settings but couldn’t find an option for them. I know what it’s for but can’t figure out why it came on.
Maybe try unplugging the battery for 20 minutes and see if it clears it. I usually get that when it snows a lot and the car turns off stuff.
It’s actually disconnected now. I’m gonna try it here in a little bit. You’d think there would be a code but I’ve checked twice and nothing. Once with my scan tool and then using Forscan.
I hooked the battery back up but it’s still on. I found the setting for it and it’s on. I did some searching and it appears to be a common problem. Moisture gets in the connectors and causes corrosion. Where I just had that issue with the O2 sensor connector, I’d say it’s likely the problem.
