Used Oil Analysis Results
First results: factory fill was pulled out at 1200 miles. Currently using Valvoline 5W-30; it will be changed and analyzed after 5,000 miles. I'll keep updating as I go.
Gadgtfreek
Next update. I switched to SD because I have more confidence in their results than Blackstone's. Will run another at the next oil change to see if a couple of things reduce. If Silicon and Fuel come down but the Valvoline still loses Viscosity, I may swap oils. UOA 1.jpg
