Turbosmart blowoff install (non plumb back)
Pennsylvania
Hello, I just got a turbosmart blow off valve Kompact dual port P/N TS-0223-1096 and I have doubts on what to do with the hose that is attached to the stock blow off that is used for plumbing back the system? is there any delete kit? or is there anything else I can do?
thanks
Pull the hose off the intake tube and cap it with a rubber cap. Most use a 1” chair leg cap from the hardware store.
Bear, DE, USA
thanks
You just leave the hose in place and attached for the dual port install... there's nothing to do with it.
Lincoln Aviator
If he doesn't want to plump it back into the intake, follow UNBROKEN's instructions.
If you want to plumb back and be quiet, follow nzaf985's instructions.
