Turbo not kicking in?
Edmonton, AB, Canada
Driving to work this morning all seemed fine, rolling along at about 105km/h and stepped it down and the pull was definitely not there like it was just a few days ago. Vehicle doesn't even have 1000km on it yet and it seems as though the turbos weren't kicking in.
Winfire4
Arizona
I’ve had the same issue. Loss of power randomly with no warning lights or codes. Car will barely accelerate for a couple days then power will slowly come back. Hardly over 2,000 miles on my 2021.
This could be anything from bad gasoline, vacuum leak, or wiring issues (or a host of other things). The wiring issues could be that something may have come loose or even as far as rodents chewing through something. I would run through your current tank of gas, fill it up again from a different station (hopefully top tier rated), drive ~100km or mi, and if it persists then take it to the dealer.
gervas79
Trenton, NJ, USA
2021 explorer st
I’ve had the same issue. Loss of power randomly with no warning lights or codes. Car will barely accelerate for a couple days then power will slowly come back. Hardly over 2,000 miles on my 2021.[/QUOTESame issue here, been looking for boost leaks cant find any, ran fine night before, drove to work next morning mad as hell. 2100 miles on it waited a month for it to come from factory and this is what i get. was previously at dealer for oil change being over 6 months with same oil gas will get in oil. theh repaired recall for camera and reprogramed sync week later this happens
gervas79
Trenton, NJ, USA
2021 explorer st
gervas79
Trenton, NJ, USA
2021 explorer st
Have same issue now, 2200 miles on it had it since sept so figured get old oil out due to run and idle time, recall with camera done then this happened, i checked for leaks cant find any, power slowly coming back under certain acceleration higher gears. have you found the problem
CareerFiremanGuy
I had a new '11 Stang GT that was low on power, turned out to be a loose sensor on one of the overhead cam banks.
Who's to know why ST's are doing it though.
Vancouver, WA, USA
Man. I’m no English teacher, but your punctuation and grammar just gave me a really bad headache :LOL:
