Tire Rotation and TPMS
RPGR90s
I have a 2025 ST and just performed the first tire rotation (myself). I then realized that I need to reset the TPMS so the new location of each tire transmits the correct PSI to the display.
But I cannot find any instructions how to do this from either the manual or online. (Is it possible that the vehicle knows I moved the Front left tire to the Right rear??) LOL
If someone can provide some guidance, I sure would appreciate it.
They’ll relearn automitcally.
MRV568
North Carolina
That is correct, they will relearn by themself.
RPGR90s
RPGR90s
Thank You all. I assumed I had to relearn each location as this is the procedure on my 2019 Ford Edge.
2022 Ford F250 Tremor
My 2018 Ford Edge doesn't require any relearning procedure.....nor has any other Ford vehicle I have owned to date
Ditto, my Edge required nothing to relearn position.
RPGR90s
RPGR90s
I don't think it's a "requirement", but my manual specifies re-learning the new position of the wheels so the dash reports the proper pressure at each wheel location.
After a few miles driven, the vehicle resets the location of each wheel position.
