The Ultimate Launch Explorer ST Trans Brake Add-on!
Marinette, WI, USA
You all guessed it and here you go! Fully functional built-in trans brake for the Explorer st. I'm telling you guys all right now this is not a modification for everybody, you have to understand that the likelihood of you breaking something is much much higher than standard launching. And it could be anything, engine trans, driveline related.
***WARNING, THIS ADD-ON IS NOT FOR EVERYONE! A TRANSBRAKE IS METHOD OF LOCKING UP THE TRANSMISSION TO ALLOW THE CAR TO BUILD BOOST ON THE CONVERTER WITHOUT THE USE OF THE FOOT BRAKES. IT IS SIMILAR TO HOLD THE BRAKES AND BUILDING BOOST HOWEVER, IT IS USING THE TRANSMISSION GEARS TO HOLD THE VEHICLE IN PLACE. IT IS EXTREMELY HARD ON THE TRANSMISSION AND DRIVELINE COMPONENTS. WITH ANY TUNE AND LAUNCHING YOUR CAR THERE IS INCREASED RISK OF BREAKING PARTS, HOWEVER ADDING A TRANSBRAKE GREATLY INCREASES THIS RISK. USE THIS ADD-ON WISELY AND BE PREPARED TO BREAK STUFF!***
Thanks to HP tuners we now have a build in trans brake for the Explorer ST and Lincoln Aviator! This modification has been a long requested add from ZFG Racing to HP tuners! Not only did we add the trans brake feature to the mix, but we also added features to the transbrake. Those include the ability to dial in torque, air load and RRM as well as anti lag features for those big turbo applications!
Basic Features
1st and 2nd gear transbrake launches
RPM control
Independent Torque control
Independent spark and fuel control for “anti lag”
“Bump” control for bumping into the staging lights
This add-on includes data log/revision cycles to dial in the launch on your ST and up 3 different tunes for different traction levels!
https://www.tunedbyzfgracing.com/product-page/2020-23-ford-explorer-aviator-3-0l-transbrake-add-on
Dominican Republic
Ford Explorer ST 2021
This feature add with HP MPVI only? or with RTD
