Sun cover
C_L213
Salem, OR
Looking to buy a windshield sun cover any recommendations?
Caster
Gulf Breeze, FL
26 Explorer ST, 21 Bronco, 24 Ranger Raptor
It's easier to have a good tint shop install a layer of UV shield across the entire windshield. Barely affects the light coming through, but drastically changes the UV rays coming through the windshield. It will drop the interior temps signiificantly as well as protecting the dashboard.
EDWYER
Black 2020 ST
Just don't go too dark.
Massachusetts
2023 ST
Gulf Breeze, FL
Totally agree! Minimal tint, primarily just a UV reflector. I've done it on all of our vehicles, including my wife's '26 ST last week. Makes a huge difference in heat inside the car on a sunny summer day!
C
C_L213
Salem, OR
Thanks ill look in to it
C
C_L213
Salem, OR
I
I know. I got pull over and got a ticket last month for illegal tint . I bought it tinted already. I had court yesterday they reduced the fine . I told them I was not removing it
Caster
I have the lightest ceramic tint on my front windshield that the place I had do it offered. I think it is 50%.. It is barely noticeable at all when driving day or night. I was nervouse while it was being applied since it was the full front windshield but I was really happy with the results when it was finished. I still use my Intro-Tech sun shade. Together they work very well. It does make a better difference using both and not just relying on the ceramic tint alone. Putting the sunshield in the windshield or removing it takes like 10 seconds.
EDWYER
Black 2020 ST
I have the lightest ceramic tint on my front windshield that the place I had do it offered. I think it is 50%.. .
50% for the front windshield is dark, 70 or 80% is light. You are misinformed.
Massachusetts
2023 ST
3M makes a 90% as well. Crystalline CR90. Most installs i've seen use 70/80% and will be pretty undetectable unless you know what you are looking for. Even 50% isn't that bad but a little more noticeable that the windshield is tinted.
Caster
I'm clearly not the one misinformed on what tint percentages mean and are. 50% Is not a dark tint. If you were in my vehicle and I didn't tell you the windshield was tinted, you wouldn't even know it was. Even though it is a very light tint, I was still nervous when it was being applied. The business does this pretty often and they assured me beforehand that I would barely notice. They were absolutely correct.
23 Explorer ST
I have 55% across the entire front and you can’t really tell it’s tinted. Definitely helps with the UV protection.
Front driver and passenger doors are tinted the same as the factory rear doors.
