Stock speaker replacement help
rhite95
Melbourne, FL, USA
Do you think it would help to replace the 3 1/2's mid's also?
This is what I have got so far.
Focal IS Ford 690
Focal IC Ford 165
Do you think it would help to replace the 3 1/2's also?
Focal IS Ford 690
Focal IC Ford 165
I have been thinking about replacing the speakers in our ST. What do you think about the sound difference now that you have the Focals installed?
I installed the Focal Speaker.
What is the 3 1/2's ?
How do you like them? Noticeable difference?
Anyone considering replacing the speakers should spend some time and do some quality sound treatments first. You will likely be amazed at the difference in quality once you eliminate all the buzzes and rattles.
Funny that you mention that as I was just looking up sound deadening. You had mentioned ResoNix before.
Sound treatments are kinda like the building block for everything else. Without a quality install you can’t have good audio and the install starts with treatments. I did my whole car long before I started the audio and it made a massive difference.
rhite95
rhite95
Melbourne, FL, USA
They are the mid range speakers in the front doors
I should have put that in the post.
rhite95
rhite95
Melbourne, FL, USA
I have not installed them yet. I just want to install it all at the same time.
rhite95
rhite95
Melbourne, FL, USA
I am going to have that done also.
Gonna be honest here…having it done and it getting done right are largely 2 different things. Shops will slap in some CLD and say it’s treated…that’s just a small part of it. CCF, butyl rope, Tesa tape, Thinsulate, etc are all part of the puzzle to do it right. I have a log here just on deadening I think and there’s a good read on the Resonix website. Learn what all the products do and don’t do so you can be specific with a shop if you’re having someone else do the work.
rhite95
rhite95
Melbourne, FL, USA
Thread Starter #12
I get where you are coming from.
I just want it to sound better than it does now, I just wanted to know if it would be beneficial to replace the mid's . Thanks for taking the time to read my post !!
Waupun, WI, USA
Resonix's site is a good resource. I really don't care for the guy, and refuse to use his products, but the site does have good information.
Also, better hi-res source material makes a huge difference. I don't listen to XM, or anything through bluetooth. Hi-res material through a USB cord sounds considerably better.
