ST aftermarket add-ons
My ST is Better!
More to follow stay tuned, Borla ATAK exhaust carbon fiber tips, 24" carbon fiber Vellano wheels.
Toronto, ON, Canada
What tires were you thinking of using? Just wanted to pass on 285/30/24 fits nicely on a 24by10 rim with 35mm offset. If I reach around I have about an inch from the tire hitting the shock. I will just let you know it’s pretty tight at the top though. Maybe 1/2 max .... not sure if you would have issues if you did anything with a larger radius then what I am running.
Truck looks good
My ST is Better!
My ST is Better!
Yep 285/30R/24 24X9.5 front 24X10 rear, thanx bruh!!
My ST is Better!
My ST is Better!
Have you installed the wheels yet? Any photos?
Here you go!
CGainz
NYC, NY, USA
Dope ass wheels man! What the ceramic run you? I have the carbonized grey. Thinking ceramic for protection or wrapping it matte military green like the G-wagon
My ST is Better!
My ST is Better!
Thanx ceramic was 1000 buks
Bear, DE, USA
24x10 +25 all around with 285/35/24 rubber is the proper size for this car. I wouldn't stagger my rims if I didn't have to. Looks good though will you be lowering it?
My ST is Better!
My ST is Better!
Yes I will be lowering it!
Bear, DE, USA
Here’s mine with 24x10 +35 285/35/24 toyo ST3’s. Waiting on springs to drop but zero rubbing! BEB8C4B9-0695-45CF-98F7-A1EED01FAB0C.jpeg 78AAE795-0C0C-40AA-A925-FAA7E641E3C0.jpeg B32D3B40-272F-4A85-BEB1-16FF74DAC5EF.jpeg
sreed
Kansas City, MO, USA
Why the different widths? 10.5 will easily fit if you wanted to go wider and run a 305.
Your stance on your St looks good. What tires are you running?
I Bleed Ford Blue
23 Rapid Red Explorer ST
He's running 285/35/24 toyo ST3's
