Road Paint removal
Philadelphia, PA, USA
Anyone know how I can remove white road paint on plastic trim and wheel well of my 22 ST? I went to the local automotive store, and the guy recommended something. Looked at the back label and it’s clearly said ” do not use on plastic.” So much for expert advice.
I’d try to find out what actual kind of paint it is first. That might narrow down what products will work. Ask a body shop too…they probably deal with it from time to time.
powerboatr
if its DOT stuff , it has alot of plastics in it
is it DRIED completely?
you may be able to get a plastic razor blade and peel it off, especially if the plastic had some protectant on it
try mildest means first
HOT soapy water, soft cloth
or wd 40 on a cloth and saturate the paint, then try how soapy water again
you can use acetone, CAREFULLY wipe in one direction and do not over saturate the area, followed by HOT SOAPY water and rinse
mineral spirits may also work, again do not over saturate and rinse with hot soapy water followed by clear water rinse
DudeMasterson
Thanks! I’ll try to find out what the DOT uses….
DudeMasterson
Thanks so much !
I had some luck using mineral spirits. I wouldn't use acetone on the plastic though. If you do you have to be quick to remove it or it will start to soften the plastic.
